2008 Jeep Rubicon manual well equipped - $18k obo Full driveline replaced
395North
Adventure Beckons
2008 Jeep Wrangler Rubicon unlimited Manual 6 speed. (SOLD WITHOUT TENT).
I did not wash the vehicle or engine compartment. It is presented with full description and honesty.
$18K (will consider lower with the removal of a few parts). Otherwise ill part it out.
Unfortunately I’m parting with this vehicle after a long history and exceptional maintenance.
I planned to install a Motec LT V-8 swap, but a new project came my way that I couldn’t resist and I have way too many cars taking up space.
This mall crawler has never been offroad.... 250,000 miles but every bit of the driveline has been replaced under Chrysler Lifetime Driveline Warranty (except for heads and axle housings).
All suspension has less than 40k.
Recently replaced/NEW in the last 30,000 miles by Chrysler: Entire engine, radiator, clutch slave, brake master, thermostat & water pump, gas tank/fuel pump, front axle shafts/CVs-new style, Couple of sensors, all Fluids, transmission, transfer case, front & rear diffs). The only things that have not been replaced in the driveline are the original heads and axle housing. There is a little bit of lifter click, but I don’t think it’s necessarily a problem, and if it is, a brand new OEM heads about 400 bucks.
THE BAD: 35’s need the regear, but it comes with 4.88 set brand new in the boxes. Will make a huge difference. Track bar hole is wallowed and needs to be tightened occasionally or have a welded/washer/sleeve.
Suspension: Icon Stage 4 4.5” lift
• 2.5” CDCV remote reservoir
• Front icon springs, rear trac bar, control arms, Icon front bump stops. Welded mounts, etc
• Synergy Rear HD synergy springs
Front end / Synergy front steering
• * Fox 2.0 ats steering dampener
• Front D44 axle welded, gusseted, and sleeved
• Teraflex front big rotor kit. Stock calipers pushed out with larger rotors
• S8002 Synergy Chromoly tie rod
• Synergy JK Front Steering Correction kit 8001 Synergy JK High Steer Drag Link Kit And flip (taper drilled). Draglink flip performs amazingly well, but it takes a little getting used to on the road when driven spiritedly. Can be flipped back.
• 8005 Synergy JK Front Track Bar Bracket
• Synergy Steering Stabilizer relocation bracket. Synergy Steering stabilizer clamp 8003
• Synergy steering Brace Kit - Track bar and sector shaft. 8069-01 Front Track Bar Brace. 8069-02 Sector Shaft Brace
• Synergy Track Bar Front. 8075.
Exterior
• Wheels AEV Pintlers
• BFG KO2 35” (2 are new)
• ARB front and rear bumpers w/tire carrier (front bumper needs a repaint. friend added a coat that just discentegrated)
• ARB front and rear diff covers
• AEV rear Steel corners with gobi rear mounts welded in place
• Front and rear ARB bumpers/tire carrier
• Rhino rack backbone rack system with custom extrusion mounts and rack bars
• Adams front driveshaft.
• Custom sliders
• Minimal wiring mods
• * Warn zeon 10s synthetic (6 month old motor)
• * Baja designs lights all the way around. XL80s, squadron Pros, Squadron fogs, S2 reverse
• * Switch-Pros solid state switch system with bluetooth control
• * Trucklite LED headlights
JUST REPLACED
• Brand new PSC heavy duty shaft power steering pump. I think it has a bubble because when you start it sometimes takes a second for pressure to kick in.
• New fuel tank and fuel pump
• New Centerforce Clutch, throwout bearing, slave-n-master.
• Just replaced: Front tierod and drag link ends, synergy sway bar links, front axleshafts and cv joints, front trackbar
• Dealer Airbag recall replacement
• Starter just replaced
Interior
• leather Rubicon seats front and rear. Front Seat airbags removed. 08 never had them
• * AT Adventure Trailers interior rear cargo rack
• Rear fuse panel
• Underseat Drivers lock box
• Ram mount built into console
• Weather tech floor mats
• Rear fuse panel and junction box
• Rear hatch light
*Extra Parts Box:
• NEW misc parts: swaybar disconnect, set of front end joints: drag link ends, tie rod ends etc.
• Extra NEW starter
• Extra NEW driveshaft
• New Yukon 4.88 gear set ready to install
• Synergy adjustable Control Arms $1275(might keep these for FJbuild)
• 8051 Front Lower Adjustable Control Arms
• 8052 Rear Lower Adjustable Control Arms
• 8053 Front Upper Adjustable Control Arms
• 8054 Rear Upper Adjustable Control Arms
395North
Adventure Beckons
