2008 Lexus GX470 Denver, CO $18,000 *SOLD*
flatwerx
2008 Lexus GX470: $18,000 Turnkey and ready for adventure
3” Dobinsons Nitro with LT rear
- Front Springs C59-314
- Front Shocks GS59-220
- Rear Springs C59-701V
- Rear Shocks GS59-575 Long Travel
SPC Upper Control Arms
RSG Body Mount Chop
5 35x10.5/17 Kenda Klever (rotated every 5,000 miles)
New AGM battery and voltage booster
TC spindle gussets 201,000
TC cam tabs 201,000
5 17x8.5 with a 0 offset KNP Kansei wheels matte black
OEM 8.2 elocked rear end from 2016 4Runner Trail, wired to OEM Land Cruiser switch
Regear with Nitro 4.56 gears with 85/140 gear oil
Flowmaster 40 exhaust
4x4Colorado Nimbus 2.0 hard shell RTT (new as of March 2023 and only used 3 times) mounted to Prius rack
OVS 270LTE awning with walls (weighs 31lbs)
Currently sitting at 233,150 miles (Not my daily but does get driven). Ready for another 200,000 miles: all work performed by RSG, me or the best Toyota Master Technician in Colorado
I do have a binder of receipts for work done while in my ownership as well as a little black book of maintenance and everything has been uploaded to CARFAX.
ALL OEM done at 218,153: Timing belt, water pump, tensioner, serpentine belt, water inlet housing o-ring and FIPG, thermostat, Rear Main Seal, Cam seals, transfer case seal, power steering rack, power steering pump, power steering lines, inner/outer tie rods, starter, alternator, valve cover gaskets, knock sensors, PCV valve and hose
OEM GX460 front calipers/pads/rotors and rear GX460 rotors (yellow calipers): 210,569 miles
OEM radiator, cap, and hoses replaced at 207,640 (have extra new radiator)
OEM LCA’s replaced at 190,729 (have extra used OEM set for rebuild)
OEM Wheel Bearing/Hub (front driver/passenger) replaced 207,640
OEM 5th Gen CV axles 200,000 (have trail spare)
Relocated Dorman washer bottle
BlueSea fuse block mounted under hood for ditch lights, rear bumper lights, Midland GMRS radio
Switched rear power with 12v, battery meter, and USB
Midland MXT275 GMRS mounted under driver seat with RJ45 pass through and 6db antenna
Cut front and rear bumper
OEM spare tire carrier delete
RAD Rubber engine splash guards (have extra set too)
DuroBumps bumpstops front and rear
Crown SS brake lines front and rear (extended 3” rear)
Oil and filter changed every 5000 miles with Penzoil 5w30 Synthetic (Fumoto valve installed at 190,000)
Transfer case and transmission fluid changed on 5/18/21 at dealership
Apex front recovery points in silver
Trail-Tailor rear recovery points in black
Apache Off-road rear upper and lower links and panhard (I’ll include RCI lower link skids)
Rear extended sway bar links
No front sway bar but I have extended links in case you get one
MetalTech hitch
BXBuilt headlights and fog lights (no leaks) (fogs not installed)
4 3” yellow LED pods in place of fogs
Black Prado window trim
Rexing 4K dashcam
Alpha Garage TRD style grille
Mars Series ditch lights on Rago mounts
Rear bumper flush mount LEDs
Upgraded piano black Prado steering wheel
Partial wood interior wrapped in gloss black vinyl (laziness)
Owl Expedition media mount in tape player with radio mic mount and tablet mount (tape player does not work)
USB and USB-C ports with battery meter (no cigarette lighter)
Prinsu roof rack
Mountain Passes 3/4 sleeping platform, mounts in 3rd row jump seat
Mountain Passes spare tire mount in 3rd row jump seat mount
Mountain Passes transmission cooler mount with large Hayden cooler
Courtesy lights relocated under vehicle
RSG bolt on sliders
Full RCI steel skids with filler plate and gas tank skid
Grom VLine
Gas strut on rear barn door (strut will need to be replaced)
Rago Fabrication Modular Cargo Cage on barn door
Ebay rear door folding table
Bison Gear Attic
SAIS Bypass
Black exterior door handles in front doors (I have the rears, just got lazy)
WELLvisors
WeatherTech Floor Mats
Desert Does It seat risers (driver side only)
Redarc Trailer brake controller
Cons:
Seat bolsters have seen better days
Missing ashtray door
One of the TPMS sensors has a bad battery (not sure which one)
Plus:
Spare parts if you want them
gp01
