2008 Palomino Banshee B2 Off Road Pop Up Trailer For Sale, SO CAL USA
PabloVTA
We've posted this locally on CL, but here's the link.
http://ventura.craigslist.org/rvs/4866249011.html
We've owned it since '09, and taken it to Pismo several times.
Pop up trailer has a large deck on front with a full size tool box. Dual Batteries, on board water tank holds about 30 gallons.
Has a Queen Size bed, and King size on the front. Inside it has a shower and cassette toilet. Hot water for the sink, and external shower. Inside has a small fridge too.
Comes with a BBQ and two propane tanks.
Has an awning, but honestly, it's the only thing that I'd replace. Cover is a bit dry from the sun.
It's a bit heavy, i wont lie, for a FZJ80 to pull it, but a Tundra V8 doesn't even feel it on the freeway going 80 to Three Rivers...just sayin.
any questions, just ask. Would like 11K for it. they are hard to find, and new are 19K now.
Pathfinder7
CL link has expired. How big is the deck on the front? I have a long travel Polaris RZR that is about 62" that I'd like to squeeze up there. Thanks! -Rob
PabloVTA
I believe it's only 50 " wide, with the ramps as the edges of the rack walls.
We have a diamond plate tool box installed, so it's a probably 18- 20" less now.
lowered price as well. http://ventura.craigslist.org/rvs/4866249011.html
2008 Palomino
Banshee B2
Standard Features
11' Awning
B.A.L. Jacks with Sand pads (4)
Clothes Bar
25 AMP Converter with Battery Charger
Easy Lube Torsion Independent Suspension Axle
Entry Step (2-Step)
Exterior 120 Volt GFI Outlet
Filon Fiberglass Roof One Piece
Exterior Fiberglass Surface
Five Piece Tent
Gallery Extension Table
Inside/Outside Stove
Kitchen Faucet with Water Pump
Double LP Gas Bottles with Cover
Patio Light
Potti Privacy Drape
Roof Air Ready
Storage Tray
Spare Tire Bracket and Cover
4" Tubular Steel Frame with E-Coat Paint
18 Gal. Under Floor Water Tank
Window Curtains and Vented Bed End Curtains
Spefications
Travel Length - 20'
Travel Width - 85"
Travel Height - 64"
Interior Open Length - 23' 10"
Interior Open Height - 6' 7"
Front Sleeping Area - 66" X 80"
Rear Sleeping Area - 60" X 80"
Tire Size - 15"
Tire Load Range - 5 Bolt C
Hitch Weight (Approx.) - Dry 363 lbs.
Axle Weight (Approx.) - Dry 2258 lbs.
Cargo Capacity (Approx.) - Dry 985 lbs.
Total Dry Weight - 2621 lbs.
Front Deck Size - 50"
Options
17,000 BTU Suburban Furnace
Create-A-BreezeTM Fan (Mandatory Option)
3-Way 2 Cu. Ft. Dometic Refrigerator
13,500 BTU Air Conditioning
