2008 Toyota Tundra 4.88 Gears + Auburn LSD + 3' Aluminum Cab Over With Aluminum Shelving / Storage
isignay
$30k.
2nd Owner
140k Miles, purchased with 90k miles.
Located in San Diego CA.
4.88 Gears
Genesis Dual Battery Kit with reinforced battery tray + cab mounted CPU.
RCI armor including rock sliders with side steps.
ARB dual compressor.
ARB Elements fridge.
LifeTime aluminum camper shell, 4' over the rails, 3' over the cab. Custom aluminum mounting brackets with Bed stiffeners.
Custom Marine Grade upholstery and insulation recently installed.
17" nomad wheels and Good Year Duratrac load range E tires installed at Basils offroad in Vista.
Suspension rebuild performed last year at Basils offroad in Vista.
Auburn LSD.
Baja Designs LP6 lights with custom behind the grille mounts.
Custom aluminum shelving and bed platform.
Currently only have 1/2 of the bed platform installed, the other half is being used as a weight rack, which should give you an idea of how strong the unit is.
New power steering rack installed last year.
Icon suspension + Dirt king control arms.
Timbren Front and Rear bump stops
ARB leaf springs with an added leaf.
New radiator installed 2 years ago.
2x 12v plugs in the truckbed.
Coach builder steering kit and tie rod ends.
Coach builder power steering bushings installed when power steering rack was replaced.
Truck has been from San Diego to Cabo 4x without issue.
Used but not abused.
Our family is growing, not in a rush to sell, just hopeful a family can put it to good use.
Truck will be in Cabo from May - June.
Happy to add details or answer questions as they come up.
Truck is a hybrid camper / family truck, built well enough to get you to a remote spot, but comfortable enough to cruise on the freeway as well.
No weird noises or vibrations, the truck's been well maintained.
Photos of the aluminum rack with the plywood are older photos, these were taken before the marine carpet was installed.
I have a pair of 110W solar panels which connect to an Anderson cable directly mounted to the batteries so you can run the fridge / accessories for days while camping.
Can include a Spring Bar family tent with the sale.
Photos:
isignay
gp01
