2009 Galway Green Range Rover
thewarhammer
Range Rover Sport HSE 4.4 V8
6 speed auto ZF transmission
Galway Green
Tan leather
Luxury package
Hey everyone!
So I am putting my truck up for sale. The truck has been beyond solid for me and I don’t really have to sell it but I figured I would put it up here. I drive the truck everyday but will be getting something else shortly as we need something bigger (New RR). So about the truck…. This truck is pretty rare Galway Green and has been totally and completely maintained by me. If you know late model Rovers then you’ll probably know this 4.4 jag motor is a really good motor. The transmission is great as well as it is made by ZF who makes quality stuff. These 4.4’s do not have the chain issues or anything that the newer 5.0’s have. Anything it ever needed, I bought it and installed it myself. It has pretty much a complete G4 conversion with all the OEM G4 parts that were available aside from the raised air intake as I did not want to start cutting up the fender. I have both keys, all manuals and clean NJ title in my possession. No check engine light. I have a GIANT folder of receipts and documents that go with the truck.
Maintenance
OEM Alternator
OEM belt tensioner
OEM secondary tensioner
OEM idler pulley
OEM serpentine belt
OEM fan belt
OEM Steering rack
CHF 11s full steering fluid flush
OEM tie rod assemblies
OEM front lower control arm assemblies
Arnott AS2809 front shock assemblies
Front Timken wheel bearings
Rear Timken wheel bearings
OEM Roof Rack System
Full Transmission Service with OEM fluid
Front differential service
Rear differential service
Transfer case service
Front rotors
Rear rotors
Front pads
Rear pads
IID diagnostic tool
Extra stuff
OEM G4 ladder kit
OEM mud flap kit
OEM side step kit
OEM front light guards
OEM rear light guards
ASFIR rear diff skid plate
Custom Black Crow Design gas tank skid plate (zinc coated)
Terrafirma 30mm wheel spacers
Atlantic British front sway bar bushing
Atlantic British rear sway bar bushing
ARB On board air compressor (hidden under hood)
Maxtrax recovery boards (tan)
Maxtrax mounting pins
Prinsu design mounting kit
Nitto 265/50/20 tires
20” RR wheels
Recovery Equipment
Midland Radio setup mxt275
Issues
The dreaded electric E brake actuator. It never bothered me because I never use the E brake anyway. The brake light is on but it is like $1000 so I didn’t plan on fixing it. It has been like this for years. Every once in a while, the driver side window makes a noise because one of the clips in the window is broken. The motor and everything is fine, it’s just a small clip that holds the window to the mechanical assembly. Guess what? Rover will only sell you the glass with the clip which is like $700. For 700 bones, I have dealt with the occasional noise. This is it. No other issues.
Will get some more pictures and information as I think of it. I will update the thread. Price is $13000 and it is located in Northern NJ. The prices for these things are all over the place so keep that in mind.
Let me know through text or email if anyone is interested. My phone is 201-253-5755. Email is ValponeEngineering@gmail.com. Thanks for looking everyone and have a good one.
tbnd88
