2010 FOUR WHEEL CAMPER GRANDBY SHELL
TGK
CAMPER IS SOLD. TRUCK STILL AVAILABLE - For Sale, 2010 FWC Grandby Shell. Original Owner. Good/clean condition and located in Portland, Oregon.
Reason for selling is that my wife and I rarely use it anymore. We now more frequently use our trailer as a basecamp. Purchased March 2010 direct from factory.
See detailed list below. Check Craigslist link for photos. If someone is seriously interested, I can send additional photos if desired. The only negative is that in January, I discovered a small leak near the rear of the camper. Prior to this winter the camper never leaked and this likely occurred in the pasts few months. I took it over to the Portland FWC dealer, 1040 Overland, and they were able to seal the leak. They diagnosed the leak as originating at the rear of the two Yakima Tracks on the roof. They removed the old caulk and the rear screws and reset everything. I recently washed the camper and truck and hit the roof with a substantial amount of water and there are no signs of leakage. There is no discoloration in the headliner. It is only apparent that there was a leak on two of the wooden ceiling strips at the rear and also where some mildew discolored the roof panel over the cabinet and ran down the wall into the closet. I’d be happy to send photos separately of these areas if interested.
Asking $8,500. Go to Portland Craigslist to see photos.
https://portland.cra...6833774767.html
- Fits Full size trucks with 8ft bed.
  • Gas struts for roof lift assistance
  • Extended Cabover with 48” x 77” bed in standard position and queen plus at 66” x 77” when fully extended
  • Rieco Titan Jacks like new. Camper only off truck once in 9 years.
  • Floor is like new as we used a rug on it.
  • Screen Door
  • 8’ Fiama Side Awning
  • 10 ft Yakima roof tracks (tracks only)
  • Rear wall steps
  • Pre-wired for solar with roof plug
  • Wired at factory for 12 volt with 12 volt outlets installed
  • Opening front window with new rubber seal.
  • Privacy Curtains
  • 2 factory installed large closets in rear corners
  • 2 factory installed small “pantry” cabinets in front corners
  • Lagun pivoting dinette table with qtr sawn oak top.
  • Galley shelf on drivers side
  • Roof Vent
  • Awning style window on passenger side
  • Fire extinguisher
  • Room for up to 40 gallons of water in 5 gallon containers under bench.
503534503526503528503529503530503531503532503533
I am also selling the 1999 Ford F250 XLT SuperCab 4x4. Will sell truck and camper as a pair for $18,500. If sold separately, camper need to go first. Contact me if you wish to see additional photos of the truck.
  • XLT Super Cab with 8 ft bed 4x4 with shift on the fly.
  • Original owner - 103,400 mile. Original manual and sales brochure. All receipts available. Very clean condition. Never wrecked.
  • 5.4L EFI V8 with 5 Spd Manual Trans
  • Preferred Equip Pkg with Cruise, Tilt, Air, Power windows, etc.
  • New brakes / calipers June 2018
  • New clutch assembly January 2019
  • New spark plugs/ignition wires & battery May 2017
  • 6.5” Sony CarPlay Android Auto Stereo installed June 2018.
  • Michelin LTX A/T2 tires, including spare. Good tread remaining. When parked, all tires covered with wheel covers.
  • 4:10 Ratio
  • 38 gallon fuel tank
  • Trailer Tow Pkg with trailer tow mirrors, electric brake wiring and 7-wire harness
  • Class lll hitch
  • Camper Pkg w/hvy duty battery, alternator & auxiliary rear springs
  • Running Boards
  • ABS Brakes
  • Privacy Glass
  • New Front Halogen Headlight Assemblies
  • Sliding rear cab window
  • Yakima Rack Rails over cab
  • Rubber bed mat
  • Never in an accident and all receipts available
  • All routine maintenance performed by Landmark Ford since original purchase
503535503536
TGK
BOTH TRUCK AND CAMPER HAVE SOLD
Key details of what the truck came with are shown here.
  • 4:10 Ratio
  • Class lll hitch
  • Running Boards
  • ABS Brakes
  • Privacy Glass
  • Rubber bed mat
Goldenbora
