Looking for some advice and or experience with doing an install like this.
I have a 2010 Yukon XL 2500 (6.0L gas 4WD) - and I would like to add a second battery and a high amp alternator.
I've been doing my research , and I think I've got most of the details down , but I've run into a few sticking points.
Basic system layout:
Odyssey deep cycle installed on the already-existing battery tray in the driver side front corner.
I would like to keep the 2nd battery isolated in some fashion so that I'm not drawing down the start battery.
I intend on adding a 12v to 120v inverter along with some extra lighting - these would be one of the main reasons to add the 2nd battery.
I've got a number of options for adding a high amp alternator, including buying one from a place like Mechman - or going with a factor 220amp from a later year GM truck
The alternator seems to be one of the sticking points. I haven't been able to determine yet whether my truck has a "smart" alternator. I've talked with Mechman - and when I laid
out my plans - they highly recommended against using a high amp alternator with a 2nd battery system that is isolated . The response I got from them said:
I would never run an isolator with an RVC controlled system. Parallel the batteries charge and ground. And then install the alternator according to the instructions we send. Your truck being a 2500 might not have an RVC sensor on the stock negative ground wire but if it does look at the type two instructions in the attached document.
Back to the isolator, there is no good that can come from it with a high output alternator. First most of them have significant resistance through the isolator which results in a high voltage drop and that is even worse with a potent alternator. If the point of the isolator is to allow you let one battery or batteries heavily deplete while making sure the other can start the vehicle then a high output alternator would be the last thing you want as it will put power back in way to fast and smoke a battery or if the bank is big enough even its own rectifier.
Now I do not believe my truck has an RVC "smart" alternator - I haven't found the negative ground sensor - and I've run the test to see if it exhibits the behavior of a RVC system - but Mechman's assertion using a high amp alternator with an isolator is a really bad idea - is something I've only heard from them. So that is one of my sticking points. Because I'd like to be able to run an inverter from the 2nd battery - I think I'd like to be able to have full alternator charge going to that battery. My other option is a DC to DC type charger like ones sold be RedArc to keep the secondary battery charged. I believe this would avoid the issue of the alternator having an issue if the secondary battery was really depleted.
But putting that secondary battery on a DC to DC charger - would restrict the potential charge going to that battery to the rating of the charger. Which might cause restrict my ability to run an inverter from it.
