Selling an incredible 2011 Horizon Adventure Trailer. Probably one of the most loaded trailers ever produced by AT. I picked it up in January 2011 and used it a few times. I'm selling due to the Habitat is finally coming into production and I'm also picking up a 2012 Jeep Rubicon for Mario and Martyn to completely redo into a Habitat. The trailer is awesome as you all know and hopefully it will go to someone who appreciates fine and durable workmanship. The price is $15,500. This is a considerable reduction from the purchase price (no taxes involved
I will provide all receipts from AT Trailers to the buyer.
Equipment list:
Horizon Trailer - color olive grey with black chassis
Steel powder coated nose box
Two fuel cans & AT holders for trailer
19 Gallon Roto-Mold Water Tank with 1.25" opening, 1/2" drain plug and pump with extra drain plugs
Auxillary 12V power wiring with night light, ARB Adventure Light, 3 fused outlets, battery tray and hold down
12V marine grade power outlet, locking type, installed on driver side of nose box
Horizon LED interior lighting; 3 x 49.5" long LED strip lights, 1 in kitchen box, 1 in side box, 1 in main box, all controlled by modulation dimmer.
Valve Regulated AGM group 31 deep cycle battery 105 Amp
Carmanah RV-25 Amp Solar Panel Charge Controller and surface mount
PowerFilm Solar Foldable Solar Charger, 60 watts (3.6 Amps @ 15.4 Volts).
Daisy Chain Accessory to connect two PowerFilm panels in parallel to increase current
15 foot PowerFilm Extension Cord
Weather-Pack Connector kit
Noco Marine Series On board 20 Amp (10/10) dual battery charger & maintainer with shore plug
Electric Braked Axle Upgrade with 10" drums, includes break-away kit 5/5 bolt pattern to match Jeep JK
Multi Axis Coupler, 6000 lb, Class III
Slide out 2 burner stove, cutting board, compartment dividers, 11 lb propane cylinder and bracket
6x6 F-35 Awning and telescoping brackets
Eezi-Awn Series 3, 1800 Roof Top Ten 70"x96"
Additional sheet for Eezi-Awn 1800
ARB 50 QT Fridge. Capacity: 50 qts. Cooling capacity: +50 degrees F to -0.4 degrees F
Full extension slide mechanism for refrigerator
Transit Insulating Bag - 50 QT Fridge Freezer
17x8.5 Argent Wheels from AEV
Wheel Adapter to adjust back spacing for Argent wheel
2 Lt285/70R17, BFGoodrich Mud-Terrain T/A Km2
Deluxe stainless steel sink complete with mounting instruction and all mounting hardware
6 LED Rectangular HD Fllo Light 4"x6" (this is the backup light)
Manchester 11 point propane cylinder & bracket - 2 units
Four concealed sub-chassis LED lights tied to reverse circuit to aid visibility when in reverse
*This unit has very cool interior LED lighting - white in color with a dimmer switch. Keep in mind this has 2 marine batteries which provides a crapload of power for extended trips. I'm also including the two solar panels. With these panels you will have an unlimited supply of power providing the sun is shining
There is very slight paint chipping on the front right and left side panel due to occasional rock hits when towing. The same goes, on a very minor basis, on the two propane cylinders. Other than these minor issues it is in perfect condition.
My email: bellpilot7@gmail.com
Cell: 626 840 1176. I look forw
ard to answering any/all questions. Located in the LA area (CA).
Equipment list:
