2011 Tacoma, adventure ready
2011 Toyota Tacoma TRD Sport
Lower Miles on the highly sought after 4.0
Automatic, 4x4 with front and rear limited slip.
$25k firm, seattle area Washington
(509) 607-6113
2.5" lift with oversized Bilstein shocks and 660+ overload heavy OEM Dakar leaf Springs in the rear.
Baja Rack with amber and white led light bar.
Snorkel with Pre-Cleaner (filters contaminants before they get a chance to make it to the air filter)
White Canopy with aluminum supports to truck bed.
Well used Yakima Roof Top tent in decent shape.
Custom bed/cargo platform with sliding drawers (for storage and camp cooking) and cutouts for 2x 5 gallon fuel/water containers.
Solar shower (you pressurize it with an air pump, bicycle or otherwise) holds approximately 3-4 gallons of water, heats up in the sun.
2x Custom bicycle racks (driver/passenger side) with rocky mountain thru-axle clamps.
Ironman full Skid Plate (protects engine, transmission, transfer case and the exhaust cross over).
Drilled and Slotted rotors with paired break pads.
Rock lights (R,G,B,W) with on/off switch and light control via.
"yellow wire mod" for full limited slip front/rear while in 4 low.
8" Tablet style stereo with wireless Android Auto and Apple Car Play, stock JBL speakers with OEM subwoofer.
Relocated 7 pin and flat 5 trailer plug for increased departure angle.
Tailgate brake/signal/reverse lights
4" Reverse LED lights in the bumper.
LED Fog Lights
Console Safe with keyed lock.
Tinted windows all the way around.
Discreet Winch Mount with two recovery points and a 10K Synthetic Line Smittybilt H20 (waterproof to the point of working submersed) with wireless and wired controls.
This truck has been religiously maintained and is very reliable.
Recent Maintenance includes:
New Steering Rack and Tie Rod
Full fluid service (Transmission, Transfer Case, F/R Diff, Steering, Brake, Coolant)
Blower Motor Resistor
Air Filters (Cabin, Engine) Engine recently upgraded to K&N with the addition of the snorkel pre-cleaner. Only OEM filters were used previously.
Fresh Oil Change
New OEM Spark plugs
Valve Cover Gasket
Recent alignment post lift kit (approximately 5,000 miles ago.)
U-joints and Carrier Bearing on the rear drive shaft.
New Windshield (doesn't make a difference to you... But it's brand new)
The truck is turn key and I would drive it anywhere tomorrow.
Now, the short list... Cons:
There are a few shopping cart dings and kisses from branches on narrow forest service roads.
The 2/4 plastic caps from the wheels have broken off.
Let me know if you have any questions.
Clean Title in hand!
tacomabill
what hardware did you use to make that side mount bike rack? looks like some sort of rail cap you attached a metal plate to and a fork mount for the front.
Clemtiger84
