2011 Tacoma DblCab TX Pro, ExPo platform ready to take further
Hobietim
Interested in an overland platform ready to finish building out or modifying? At a good price with some of the nice to have stuff already done?
2011 Toyota Tacoma, Silver, V6, 4Speed + Overdrive, one owner (ordered new), every option except Bluetooth (Parrot BT added later), 79,900+ miles. This has the rear ELocker axle lock, hill descent, LSD disable, 110V inverter with park interlock disabled (means you have 1000W when driving, not 400W).
All Toyota recommended maintenance followed.
Upgrades, tweaks:
Toytec adjustable Bilstein 5100 Front Coilovers, have wrench set;
OME 9 leaf 3" lift rear leaf replacements and rear Bilstein 5100s;
East Coast Gear Supply left front axle bearing "fix", new (@ 50K miles) left front half shaft;
K&N Filter;
Dual Batteries, yellow top house, red top starting AGM Optima with dual battery charger/splitter;
rear axle breather extended to above gas cap;
rear camera switched for live view anytime;
6 circuit auxiliary fuse block, three circuits live three keyed, three available circuits;
12V rear canon plug in pickup bed at left rear with dual 12 ga wiring led from fused battery (used to run Dometic fridge freezer);
USB charging plug hardwired in front console;
Rear bed cap with locking rear glass and pass through flip up forward window and crank open side windows;
tied down points in rear bed;
TRD rims with BFG AT KOs (275 75 R 16)and full size spare (4X29K miles spare 0 miles);
No rust, one deer strike 12/17 repaired front quarter panel and headlight.
Available today in Missouri for $22,500, clear title in hand for you to acquire for a winter build out!
Contact: Tim Pickering, hobietim@gmail.com, pictures available upon inquiry.
4xCoffee
