StrongCo
$32K OBO
(Camper needs completed and powered) - Truck needs nothing... but camper needs finished to Buyer's taste... from $3K to $30K but then worth $50K to $100K
great cost effective start to a build and almost no better base vehicle than the Cummins platform. job change forces sale and trying to minimize losses. sorta close to break-even.... but that never works
text me 954-995-0008 (Chad Armstrong)
2012 dodge ram 5500
condition: good
cylinders: 6 cylinders
delivery available
drive: rwd
fuel: diesel
odometer: 130,414
paint color: white
title status: clean
transmission: automatic
type: pickup
2012 Dodge Ram 5500
Cummins 6.7L 370hp high output (Tuned to 400hp)
84" CA Heavy Duty
Dana S111/S112 Limited Slip Torsen type Axle
Aisin 6spd Ultra-Heavy Duty Auto Trans
2018 Cummins 6.7L engine 370hp and 88,812 miles (verified/documented)
engine swapped due to common spun rod on the 2012 6.7 when injector clogs/washes. This issue has been resolved by Cummins with a nano carbon fiber tube fuel line upgrade that provides microfiltration.
ARP headstands while engine was out, New water pump, new ps pump, New Injectors, high performance fuel setup,... Dual Opima Yellow Top batteries, Sinister Diesel cold air intake...averages 12-14mpg "loaded" measured.
Small items:
no major dings/scratches, tinted windows, looks awesome, brand new double coin tires/rubber, coated the frame fully while bed was off with POR15 (read about it) - it's awesome and fully protects rear frame and axle housing.
Truck Needs nothing. You can drive this cross county or cross continental...fly into FLL and drive away.
no low ballers or moonbats... its a fourth truck, my Toy hauler next bug out vehicle...I use it for projects and towing stuff - don't have to sell so....needs to be the right buyer. If you know Mobile cummins campers or overlanders there a waitlist and they run $100k-$750k.
Camper - Medical Habitat - Bug Out Vehicle Pod - Mobile command post or Office.
Eagle Mobile M4508
Over. $100k pod/cabin build originally... the scan system is over $3,000,000.
(Does not included any systems other than what’s pictured in the Pod)
240v and 120v circuits, milspec wiring through, LED interior and exterior, possible exterior camera system, multiple monitors, high quality mobile grade lockable cabinets, antimicrobial heavy duty carpet ceilings , walls and industrial rubber floor.
(2) Carrier Air V AC units, fully tested and operational.
American made heavy duty 3/16in cold rolled steel construction, ballistic / bulletproof to small arms fire, easily modifiable to add windows, change overall shape or height of the pod, add to or subtract with normal MIG welding...
Available that I was going to add... (contact me if interested) (2) 300watt Phillips solar panels, 2400watt HD inverter and charging module. To be mounted on each side of the slant back roof leaving the nonskid track in the middle. Willing to mount for free for the right buyer...
I can also discuss finishing the build for you and provide a trusted partner if you want to add a Head/toilet (one side of desk)
And bedding options on back wall... very easy to do or you can get complex... or add a cot and camp toilet for now and propane stove lol and start hitting the road on the cheap... I was also going to add bike racks surfboard slots and a spot for the generator in the rear frame extended area... I can draft this on CAD if you like...for ideas etc.
It’s short money for a modern Cummins, reliable mods (must do’s) and a bulletproof camper... drives perfect and gets 20+mpg
Listed locally for sale in Boca Raton FL - contact me with questions - may sell at anytime!
diesel cummins 2500 3500 4500 550 450 superduty truck
2012 dodge ram 5500
condition: good
delivery available
drive: rwd
fuel: diesel
odometer: 130,414
paint color: white
title status: clean
type: pickup
2012 Dodge Ram 5500
84" CA Heavy Duty
Small items:
Eagle Mobile M4508
