2012 Fuso FG 4x4 Flat Bed
JGrey
I’m currently looking to re-home one of my Fuso FG 4x4. It is currently built out as type 6 firetruck. It has an automatic turbo diesel with limited slip differential. The body is a Protech aluminum flatbed body with tunnel box. Last year, I had a new factory motor installed and fresh tires. Both have approximately 5000 miles on them. No leaks and minimal surface rust. DOT inspection from dealer competed March 2023. Truck has 63000 miles on it.
I’ve run Fusos’ in my firefighting business for over six years now. They are impressive with their ability to access difficult to reach terrain and their small footprint. I’ve spent fire time and all kinds of chassis and settled with Fusos. My maintenace bills on these have been reasonable considering where they go. Others companies that run Ford or Dodge chassis have seen higher maintenance bills for the similar amounts of use.
I plan on building an overlander on my other Fuso for my retirement which is fast approaching. They get around 12.5 MPG and can accept around 5000 pounds of “load“ on the flat bed.
This Fuso is currently built as a fire truck, but I would remove the fire skid and boxes if you are looking for just a flat bed.
I’m asking $75,000 as a fire truck and $65,000 as a flat bed. The truck is located in south eastern Arizona near Portal.
gp01
