2012 JKU HVAC switch.
HAFICON
2012 JKU Sport no factory hard top, standard mirrors.
Looking for Some advice, pictures below is the HVAC selector pannel the knob on the right which changes position is showing an error of some sort.
Insert the key and rotate, the light on the knob starts flashing and goes for about 30-45 seconds. During this time the system will not blow air. Once it stops flashing it will blow air. So I did some research and it sounded like the pannel itself was bad. From what I read it looses calibration and the blinking light means is it having to re-cal itself every time on start up. So I ordered a new Mopar switch pannel. Same results new part installed and it stil does it. Also read about it being the blend door actuator I replaced that since it was only $20 first and that did not fix it either.
Any ideas?
