2012-Mitsubishi-Fuso-Cantor-FG-4x4 Global Expedition Extreme RV Motorhome
pugslyyy
http://www.ebay.com/itm/Global-Expedition-Extreme-RV-Motorhome-4x4-/191837194050
2012 Mitsubishi Fuso FG 4x4 cab and chassis with Global's Pangea-LT Cab-height Lifting Roof Custom Camper Body.
2012 M-F FG 4x4 chassis, vin # 013930
Off-road tire package: Super Single steel wheels with Hankook M/T 3 37x12.5R17 tires.
Locking front hubs.
Aluminum Heavy Duty Front Bumper with Grill Guard.
15,000 lb. remote operated bumper mounted winch.
On-Star.
Kenwood Excelon audio head with radio, CD, GPS/Garmin, back-up monitor, blue tooth.
60 gallon fuel tank.
Air-ride Driver and Passenger seats with Custom Center Console.
Front nose clear-coat road debris protection.
Fire extinguishers.
Length: 21' 6" Height: 102" Width: 84" Total weight: 10,500 lbs.
Height detector on driver's mirror.
Expedition Body: GXV Structural Composite Sandwich Panel construction body wall panels at 3.5" thickness.
Full Hard Walls in up or down position for security.
Hydraulic lifting roof system, with manual override.
Body length: 14' 6" Body width: 82"
Cab to cabin access, usable in up or down position.
Rear of Expedition body squared off for maximum storage.
Lowered entry door integrated into body panels.
Electric entry step system.
Rear-mount spare tire and sand mats.
LED marker lights
Exterior-access storage compartments.
7 Dual-pane glass windows.
Skylight/Roof hatch, 25"x25" with shade and insect screen.
Exterior LED area lighting on both sides and back.
Roll-up 10' awning.
Multible tie-downs at corners and rooftop.
5000 lb. tow-hitch.
Back-up camera.
Kitchen/Galley:
Aluminum cabinetry with gray powder coat finish.
Stainless steel sink with single lever faucet and separate drinking water spout.
Built-in single burner induction cooktop.
Vitrifrigo, Marine-grade, 2 drawer stainless steel refrigerator/freezer, 6.4 cu. ft.
Dining Area:
2 person dining booth converts to auxiliary sleeping for 1.
Leather 2-tone gray cushions.
Under-seat storage, one side lockable.
Adjustable table.
Multible collapsible hanging hooks for coats, keys, handbags, etc.
Flat screen Jensen TV with CD/DVD player.
Flat roof-mounted KVH A7 low-profile satellite receiver with control box.
Built in speakers.
Sleeping Quarters:
Sleeping for 2, full-size bed
Storage drawers under bed accessible from interior.
Wash Room:
Wet bath with shower and teak bench and floor mat.
Thetford cassette toilet.
Electrical:
Controls for systems management and monitoring.
12v with 120v systems, consisting of shore power inlet and interior outlets.
120v Outback systems voltage inverter/charger for AC power, 2600w.
8 solar panels @ 100w each, 800w.
Automatic circuit breakers for all 12v DC and AC circuits.
Lithium battery, 440 ah = approx. 400 usable ah, 10 year battery life.
LED interior lighting.
Climate Control:
Webasto Hydronic Thermo-50 coolant heater variable from 7,500 Btu's to 17,000 Btu's.
Provides thermostatically controlled forced air cabin heat, cabin hot water, engine-off heating, and preheats engine in cold weather.
Air conditioner with thermostat and timer controls, 12,000 Btu's.
Plumbing:
40 gallon fresh water supply.
4.5 gpm water pump.
Water filter system.
22 gallon gray-water poly-tank, thermally protected from freezing.
PEX water piping installed within cabin envelope.
Finishes:
Cabinets: Aluminum with medium gray powder coat finish.
Counter top: Slate stone veneer finish.
Flooring: Commercial vinyl, 20 year warrantee. Gray wood finish.
Walls and ceiling: White, easily cleanable fiberglass gelcoat.
Tabletop: Slate stone veneer.
Leather dining cushions.
MSRP: $274,000.00 before about $50,000 worth of customer options.
This vehicle was purchased in November of 2014 as a new demonstrator model with about 8,700 miles on it, and has very little use other than driving from the dealer, (Missouri) to Denver, to the East coast. It is very fun to drive, extremely eye catching, would make the ultimate bug-out vehicle. We can make arrangements to deliver to you for the cost of air fare, or you can pick it up and drive it home.
pugslyyy
yeah bummer that they bought it in 2014 and apparently really only drove it from GXV home.
