2012 Ram 2500 4x4 Diesel Truck Northern Lite Camper Combo
mauijosh
2012 Dodge Ram 2500 4X4 Crew Cab 6.7 Diesel 500HP Deleted, Straight Piped, Huge S&B Air Filter 6 position tuner, NO DEF Required, Built Transmission at 170K! Lifted, 35" tires on 20" Aluminum Rims
8'11" Northern Lite Camper with new Mattress, New 3700 watt electric start dual fuel Generator that stores in the campers side storage compartment but can run the AC at full power.
New 3500 Watt Inverter with remote, New AGM Mega Battery (Zero Maintenance)
Has shower, bathroom, full kitchen with oven, twin propane tanks, Huge 3 way refrigerator, super sweet, light 4 season, camper built better than all the other brands with a full fiberglass shell.
Truck is setup with all frame mounted camper tie downs.
This is a plug an play setup ready to go adventuring anywhere.
Add another $30K if you want a beautiful 21' Grady White Boat, 225HP Yamaha Outboard, trailer and extended hitch setup to use it with the camper.
Located in Sandpoint, ID
$50K
mauijosh
Ask if you want extra pics
gp01
