2013 E-350 trying to find turn signal wiring to tap into
JaredG21
Hi All,
I am just about done converting 2005ish F-Series trailer tow mirrors with marker lights and turn signals to work on my 2013 Ford E-350 van. Not an easy thing to do but I'll try and do a write up shortly. I'm stuck on the last step - I ran wires down into the drivers side foot well area to tap into turn signal wiring but I cant for the life of me figure out which wires I can tap into. I guess worst case I can run the wires through the firewall and to the actual turn signal lights but thought it would be much easier and cleaner if I could find a source in the cab. Any ideas? Thank you so much!
132730175_10221130991837880_4996483200800447129_n_53c6faf5a4705e86fa18243fc0631d5830b5f585.jpg
Bbasso
Expedition goofball
If you pull the tail light out, take a look at the colored wire and then find it in the footwear to tap into.
Hope that helps.
Yes, please post a write up for the mirror swap.
Toyaddict
Unfortunately I don't have a complete set of shop manuals for the e-series but maybe this will help? I have no clue where said connectors are in the van. 407F8A79-58FD-4BFD-A533-BCCCD4762504.jpeg ar
