2013 Four Wheel Camper Grandby Built Out Shell - Rollover Couch Dinette - $10,000
danneskjold
The camper is a 2013 Four Wheel Camper Grandby Shell, sized for a full size long bed truck (8 foot bed) but will also fit the shorter 6.5 foot bed.
It has a rollover couch, and a dinette table that I believe were installed at FWC back in the day. Really the best of both worlds, and the couch folds down into a second full size bed. I have built out the shell to include water, and a stove amongst others.
This is plumbed for propane but you will need to add a mount and a battery.
Comes with cushions for the queen sized bed extension, and can sleep 4 adults comfortably.
Includes:
Victron BMV-712 Battery Monitor with Bluetooth
Victron SmartSolar MPPT 100/30
Squadron Sport, Angled Flush Mount, LED Work/Scene
Blue Sea Systems ST Blade ATO/ATC Fuse Blocks
Blue Sea Systems 285 Series Circuit Breaker
Blue Sea Systems WeatherDeck 6 Position Switch Panel
Maxx Air 00007500K 00-07500K Deluxe with Remote-Smoke
Renogy 100 Watt 12 Volt Eclipse Monocrystalline Solar Panel
NOCO Genius G7200 12V/24V 7.2 Amp Battery Charger and Maintainer
NOCO GCP1 15 Amp 125V AC Port Plug Power Inlet
COMPACT RVLock Keyless Entry Handle- LEFT
10 lbs (2.5 Gallon) Manchester Propane Tank
ARB Portable Fridge/Freezer Slide (Black) - 10900021
Dometic SMEV HB1320US Euro Single-Burner RV Propane Cooktop
18 Gauge Undermount Sink 13x13
Marine Folding Faucet/Spout
Sureflo 4008 Water Pump
Scepter 5 Gallon True Military Water Container, Sand
Ratcheting Paper Towl Mount
ARB 814201 Retractable Awning (ARB4402A) 2000x2500 mm
Front Runner - Stainless Steel Camp Table Mounts
The bad:
Running lights don't work
Dent in the rear driver side - non structural and haven't had any issues with dust/rain coming in
Front window got destroyed so a sheet of reflectix is in its place. It's been like this for a year, and have had no issues. Cost to fix is $350 from FWC with parts and labor.
Located in Seattle. I am also willing to deliver pretty much anywhere provided you pay for gas and food. I can also help with the install.
danneskjold
I'll be driving down to LA area and back the next couple days, and could do delivery within a reasonable distance of I5 if anyone is interested.
Houie
