2013 Tacoma and All-Terrain Bobcat Camper for Sale $43,000
Truck currently has 84,500 Miles and is in Flagstaff, Arizona. I have a clean title for the truck and camper. Message me here or call/text 530-277-8371.
This truck and camper set up is ready to go. It was built for long term travel with Mexico, Central America and South America in mind. You could drive this to Ushuaia today.
Upgraded Old Man Emu suspension, and KO2 tires.
Access Cab seats have been removed (I still have seat parts) for storage area and a twice, UV light filtered water system (copied from Dan Grec) with a 15 gallon water storage tank. There is also a 6-gallon water tank in the camper and a separate 5-gallon jug for getting water from filter stations.
The camper was purchased as an empty shell and built out with the experience of several other builds under our belt. We have gone smaller and simpler with each build and this Tacoma and camper is light weight, simple and practical. Aluminum tubing has been used for the interior structure to keep the large storage areas light weight but functional and able to withstand lots of off-road miles. The seating area has been designed and built to provide storage and raise the seating level to make use of the large windows in the camper when opened. The bed is 69X75 inches when fully opened and sleeps two comfortably.
The camper has an EcoFlow Delta 2 MAX battery/inverter system that runs 120V plugs and the 12V system (2046WH). The battery charges from the engine alternator when driving. I also have two solar panels mounted on top of the camper, but they are not hooked to the system since we did not find a need for them. There is a Boxio portable toilet. The camper has a Dometic 78L,12V fridge and freezer (CRX 1080 U/F). There is a sink, an induction cooktop as well as a butane stove.
The truck and camper come with a ton of extras:
Starlink receiver (you will need to set it up in your name)
ARB tire repair kit
Compact recovery shovel
Factor 55 30-foot tow strap
Rated aluminum pully for recovery
3 rated soft shackles
ARB Jack Base
Nico Boost HD - reserve battery for jump starts
Rino recovery strap
Safe Jack hydraulic jack with extensions and collar
Gerber folding saw
3-foot breaker bar and socket for tire changes
3 Folding reflective road triangles
Induction cooktop
Butane cooktop
Outdoor mat
Two folding chairs
Heavy duty steering wheel lock
Reflective vest
sunnyaz
