Tymebandit951
2013 Toyota Tacoma TRD Offroad 4x4
82,xxx miles (will go up with daily driving)
Registered and smogged in CA
I bought this truck in 2014 when it was only about 9 months old, planned on turning it full pre runner but life has changed and it's time to let the dream go. This will be a solid platform for someone to continue building out or take out and use as is. It's a 10 year old truck, there are some scratches and dings but over all the truck is in excellent shape. Interior is very clean with very minor wear, I'm the 2nd owner and never been smoked in or even had a dog in it. Maintenance has always been completed although I don't particularly keep records of that stuff. I will get the truck professionally detailed before it's handed off to the next owner. Please feel free to ask any questions!
Asking price is: $28,000 obo
Located in Riverside, CA
Contact info: (951)941-3201
Front
JD fab lower pivot kit (installed by JD fab)
JD fab UCA double shear kit (installed by JD fab)
JD fab stearing double shear kit (installed by JD fab)
JD Fab UCA (installed by JD fab)
JD Fab skid plate (installed by JD fab)
2.5 King Ext length shocks (rebuild by Down south Motorsports about 20k miles ago)
600# King springs
2.0 King bump stops (installed by Dirt King)
Dirt King stock length lower control arm (installed by Dirt King)
Rear
King 2.5 Ext length shocks (rebuild by Down south Motorsports about 20k miles ago)
Deaver U402 Stage II leaf springs
Archive Garage hammer hangers with cross bar
Timbren Bump stops
All Pro Ubolt flip kit
Armor
All Pro Offroad Apex aluminum front bumper
All Pro heavy duty rock sliders
Pelfreybuilt HC rear bumper with swing out and jerry can holder. ("wings" of bumper were shortened by JD fab to accommodate 35" tires)
(The swing out is currently off the truck)
Misc
(5) BFG KO2 315/70/17 Load Range C (these ride much better than load range E in my opinion)
(5) Method 701 "Bahia blue"
4.88 Gears (installed by Pro Gear in San Diego)
Pelfreybuilt battery tray
Odessy group 31 battery
Baja designs flood lights (Not DOT approved version)
Baja designs S2 rear lights (Not currently hooked up)
Bushwacker fender flares
Leer 180R topper with Yakima roof rails
Decked drawer system
ATH bed stiffeners
Weather Tech floor mats
Taco Vinyl "TOYOTA" grille
Extras (not installed)
Spare OEM CV axle
Extended brake lines
Iggy switch panels x2 (one for Switch pro and one for carling switches)
Rubber fender liners
There are a few more odds and ends, including the stock 3.73 gears
Here's the link to my build page:
https://www.tacomaworld.com/threads/tymebandit951s-1-step-forward-2-steps-back-build.389082/
The bad:
-I used to have an air flow snorkel but I removed it a couple years back. The plan was to go big time LT and glass fenders but that hasn't happened and I just drive around with a hole in my fender. The easy fix would be to just add a snorkel back on and then no more giant hole in the fender.
-The driver rear courter panel has a small crack right where it meets the tail light, honestly a little jb weld would fix it but the real need is for some fender supports so they stop flapping in the wind.
-The powder coat on the front bumper is fading and needs to be repainted. I used a single $25 can of Steel-It to repaint the rear bumper and it turned out great so it's an easy fix.
Front
600# King springs
Rear
Timbren Bump stops
Armor
Misc
ATH bed stiffeners
Spare OEM CV axle
The bad:
