Not sure why this didn't come up on earliner searches but I just located this. Hope it helps someone else out.
AXLE CODES
19 — 3.55 ratio, non-limited slip (Visteon)
22 — 4.10 ratio, non-limited slip (Dana)
24 — 3.73 ratio, non-limited slip (Dana)
32 — 4.10 ratio, non-limited slip (Dana)
34 — 3.73 ratio, non-limited slip (Dana)
35 — 4.09 ratio, non-limited slip (Dana)
39 — 3.55 ratio, non-limited slip (Dana)
52 — 4.10 ratio, non-limited slip (Dana), dual rear wheels
56 — 4.10 ratio, non-limited slip (Dana)
82 — 4.10 ratio, non-limited slip (Dana)
83 — 4.56 ratio, non-limited slip (Dana)
84 — 4.88 ratio, non-limited slip (Dana)
85 — 5.38 ratio, non-limited slip (Dana)
B4 — 3.73 ratio, limited slip (Dana)
C2 — 4.10 ratio, limited slip (Dana)
B2 — 4.10 ratio, limited slip (Dana)
C4 — 3.73 ratio, limited slip (Dana)
C5 — 4.09 ratio, limited slip (Dana)
C9 — 3.55 ratio, limited slip (Dana)
E2 — 4.10 ratio, limited slip (Dana), dual rear wheels
E6 — 4.10 ratio, limited slip (Dana)
F2 — 4.10 ratio, limited slip (Dana), dual rear wheels
F3 — 4.56 ratio, limited slip (Dana), dual rear wheels
G4 — 4.88 ratio, limited slip (Dana)
G5 — 5.38 ratio, limited slip (Dana)
H9 — 3.55 ratio, limited slip (Visteon)
TRANSMISSION CODES
5 — Four-speed automatic overdrive (4R75W)
B — Five-speed automatic overdrive (5R110/Hi-Torque),
diesel
E — Four-speed automatic overdrive (4R100)
U — Four-speed automatic overdrive (4R70W)
