ANDYROO
This is a premium build using AEV – American Expedition Vehicle components and other top of the line overlanding upgrades.
It is in solid condition and has been well maintained and serviced throughout its life. It was built by and has been upgraded/modified by renowned Jeep Technician, Chris Johnson owner of Rock Tech Off-Road and we purchased it new/stock from Bob Baker Carlsbad in 2014. It currently has 109k miles on the clock and this will stay constant as it is not being used. If you’re looking for an exceptionally built Adventure Vehicle, then this is the rig for you! Located in Vista, CA
Price: $28,499 OBO SOLD
Rig detail:
Rig detail:
- AEV 4.5” DualSport SC lift:
- AEV Premium Front Bumper and Front Skid Plate
- Warn Winch 9000 and Winch Mount bracket and Fairlead
- AEV Rear Bumper and Tire Carrier, High Lift/Pull-Pal Mount/Shovel/Antenna Flag mount and Back Light.
- AEV Front and Rear Differential Covers
- AEV Slider for Rear Differential
- AEV 10.2 Gallon Fuel Caddy
- AEV CHMSL 3rd Brake Light
- AEV Heat Reduction Hood
- AEV Snorkel with Pre-Filter.
- AEV Platform Roof Rack
- AEV 5 Savegre Wheels in Black with locking lugs
- AEV Procal Module
- AEV High Capacity front springs
- Yeti XD JK Top Mount Drag-link
- Yeti Extreme JK Tie Rod assembly
- Yeti Steering Damper Mount
- Yeti XD JK Adjustable Track Bar
- Pentastar Front drive shaft
- Dynatrac Ball Joint Set.
- Falken Wildpeak AT3’s Tires 35x12x17(approximately 20k miles left on them)
- HiLift and PulPal Recovery devices
- Front Bumper Mounted IPF Off-Road Lights
- Under Hood On board ARB Single Air Compressor
- Odyssey Heavy Duty Performance Battery 48 – 720
- Full RockHard 4x4 skid plates and Sliders.
- Goose Gear Rear plate system and side cubby’s
- Heavy duty wiring to front battery for fridge in rear.
- Wired for On Board CB radio and rear antenna
- Vector full length dash bar with 2 x 67D carbon fiber arms
- Rear tailgate tray from Outback Adventure Trailgator.
- Tembo Tusk Rear Fridge Slider.
- JW Speaker from headlights
- The Rig has recently had a 105k service and at that time it underwent (1) semi–synthetic oil change and (2) multi-point inspection (3) new windshield and wipers
- Tires have approximately 20k miles left on them and are in good condition.
- This rig is not a mall cruiser and has been used as an overlanding support vehicle in the TAP business.
- All TAP company graphics have been removed.
- Known Issues: (1) Wiring to compressor and switch needs looking at as it works intermittently (2) It has various skuffs around the body as you'd expect from an off-road vehicle that gets used (3) Carfax will show an accident in 2018. All body work replacement was carried out and certified complete (4) Leather on side of Drivers seat has a small cracked area
- If you're seriously interested come look at it and then get it checked out independently.
