2014 Jeep Wrangler Rubicon $48,000
jencheff
We’re selling to make room for a new Jeep. This Jeep is my daily driver, and we drive it to Moab UT and Ouray CO every summer for long off-road trips. Comfortable highway road car yet excellent off-road. Turn-key rig for almost any trail. This Jeep must be seen to appreciate what it is.
Contact: John at 949-981-2141
Professionally built by Rebel Off Road. Meticulously maintained. Kept very clean. All service records are available complete with summary spreadsheet.
  • Mileage: 90,000
  • Nitto Ridge Grappler Tires: 37x12.50R17
  • ATX Chamber Pro II Beadlock Wheels (17 x 9) with wheel locks.
  • Rockslide Engineering Electric Step Rock Rails
  • High clearance, wide fenders from Notch Customs
  • Built Dana 44 Axles Front & Rear: Tube sleeves, Gusseted, Chrome Moly Axles, 4:88 gears, Rubicon Lockers. Teraflex diff covers.
  • JE Real drive shafts with solid core Spicer U-Joints
  • Teraflex Elite 4” Long Arm Lift with Low Center of Gravity Suspension geometry, Teraflex hydraulic Speed Bumps.
  • King 2.5” housing reservoirs shocks.
  • Large Drag Link, Tie Rod, and frame brace by Teraflex.
  • Teraflex Extreme Duty and adjustable ball joints.
  • Teraflex Big Brake System: 13inch rotors, dual piston calipers front, single piston calipers rear, High Friction Low Dust pad set. Brakes are basically RAM 1500 parts.
  • Rubicon Rock-Trac 4.0:1 Transfer Case
  • Electronic Sway-Bar disconnect
  • Rear Bumper with integrated spare tire swing arm: Expedition One
  • Front Bumper: Expedition One
  • Warn M8000 winch
  • Magniflow exhaust system
  • Custom Roof Rack
  • Onboard Air system using ARB Twin Compressor and a Two Gallon reservoir tank. Two connection ports, one under the hood the second inside by left taillight
  • Glove Box dedicated to electrical systems and switch panel, fuse block, battery power taps, ground taps, ignition power taps, air system gage and switch.
  • Rear LED back up light.
  • Cargo Area Tie Down System
  • Rear Back up Camera
  • Tailgate folding table
  • IMP Off Road Lights up front. PIAA brand LED Spotlights used as Daytime Running Lights. Headlights are LED Dual Projector Beam.
  • Jeep All Weather floor mats along with standard carpeted floor mats.
  • Wired and antenna cabling for CB, HAM, or GMRS radio.
  • Leather seats in light brown: Heated front buckets
  • Navigation System and upgraded U-Connect radio and speaker system.
  • Power steering, brakes, windows, mirrors
  • All the normal Rubicon Package options
Goldenbora
