2014 Toyota Tundra SR5 4x4 double cab - Ventura, CA - $29.5K
huerta32
2014 Toyota Tundra Double Cab SR5 4x4
Clean title
134xxx miles
5.7 V8 flex fuel
Tow package
285/75/18 (35") Yokohama Geolandar ATX tires (approx 7k miles)
5.29 gears
Auburn LSD in rear
King 2.5 Coilovers with reservoirs and 700# coils
Pro comp uniball upper control arms
King 2.5 Shocks w/ reservoirs in rear
Icon add-a-leaf
Rock sliders with kickout
Smittybilt winch bumper
Smittybilt 12k lb winch w/ synthetic line
Baja Designs LP6 Pros mounted on bumper, wired to high beams
Baja Designs squadron pro amber ditch lights
Baja Designs squadron pro amber fog lights (use OEM fog light switch)
Baja Designs squadron pro lights
Switch Pros control panel mounted next to shifter
ARB air compressor mounted in engine bay
Rear diff breather relocated to prevent water intake
Upgraded rotors (approx 7k miles)
Tinted windows
Sound deadening throughout
Pioneer 10" screen w/ wireless Android auto and Apple car play
Spray in bed liner
$29.5k obo
Willing to uninstall the air compressor, switch pro, LP6s and ditch lights to lower price
Great truck but I now have a longer commute
Slight damage to rear bumper from 26 point turn on a tight trail in the Sierras
Paint isn't perfect since I did drive it off road
Sent from my Pixel 2 XL using Tapatalk
rruff
was the 5.29 geares a big help? what you like about them?
Stock is 4.3 so 5.29 is 23% shorter gearing. His tires are ~9% bigger so it overcompensates quite a bit. It gives you a lower 1st gear and closer usable ratios; perfect for hauling or towing. If not hauling or towing, you'll probably lose some MPG on the highway, but I doubt it will be much. Some people claim the regear keeps the transmission from "hunting", but I haven't noticed mine doing that with the same diameter tire and stock gears. One nice thing is that you can easily accommodate 37s which look best IMO, and give you some ground clearance and rolling benefits offroad.
huerta32
Dirty Deeds has more experience with Tundras than I ever will
