2015 Earthcruiser for sale - Turnkey - everything included
2015 EARTHCRUISER FX “Voyager 3
$230,000. Very good condition
Contact Reed Resnikoff for additional details and to make appointment for viewing. Location South Florida.
kwazimotorr@gmail.com - 475 223-5530
Move up to the ultimate off‑road RV. Turn‑key sale. Everything included. Nothing additional required. No need to buy even a single item. If it’s not on this list, I never needed it during a 2‑year, 50,000 mile trip. Turn the ignition key and start your own travel.
House is marine‑grade manufactured.
Exceptional temperature‑insulation. Extremely quiet.
Just completed regularly‑scheduled maintenance; all fluids and filters changed.
72,000 miles on odometer. Complete service records.
4 new tires.
2016 registered, still under Fuso 5‑year warranty
Oregon vehicle inspection valid until Jan. 2021
Oregon state registered. No sales tax
This EarthcrWHEELS/TIRESuiser is allowed into all U.S. National Parks because at 21’ length, it is less than U.S Parks Service 24’ maximum.
The Earthcruiser FX model was road‑tested by the Wall Street Journal on Dec. 20, 2019. This is the link to this article: https://www.wsj.com/articles/perks-...000-rvs-are-built-for-overlanding-11576855049
CAB & CHASSIS
BASE CHASSIS
: Fuso FG 4x4; 72,000 miles
: Earthcruiser‑spec alloy wheel with off‑road tires (single rear fitment) – additional, spare
4x new Toyo A/T II Open Country tires: LT 315/75 R16 – 127/124R 10 P.R. (common size tires available world‑wide)
Bottle jack 12 ton, hydraulic, air/manual operated, w/mount
Nut Buddy – lug nut removal assistance tool, includes 33mm socket
Jack platform
SUSPENSION: Earthcruiser specs Leaf springs / shock absorbers / greaseable shackles, Long travel, soft ride suspension system, upgraded shocks
TRACK WIDTH: Front & rear axle, the same when fitted w/wheel conversion
WHEEL BASE: 134”/3403mm
OVERALL LENGTH: 21.4’ 257”/6527mm (Allowed into all U.S. national parks because it is under 24’ length limit.)
OVERALL HEIGHT: 9’11”, 119”/3022.6mm
OVERALL WIDTH: 6’9”, 81”/2057mm
WET WEIGHT (approx.): 12,000 lbs, 5443 kg
FUEL TANK: 61G 231L, mpg range 11.3 – 12, approx. range: 689 - 732 miles
Battery: 2x 270 amp/hr AGM
Heated and cooled seats w/adjustable lumbar
Center console w/cup holders and large storage area
Combination safe below center console
Heavy‑duty Alloy Bull Bar (front vehicle protection) w/steel enforcement – 2x front recovery points, LED turn signals
16,500 lb Warn winch
Radiator protector – Skid plate
Brush Guard (front vehicle protection) w/Roof Rack – protects cab / windshield / adds cab roof storage
High‑capacity tow bar (rear vehicle protection) incl recessed tail lamps, Class IV hitch receiver
Spare wheel / tire carrier – tilting, locking
Spare tire cover w/rubbish bag
12V accessory socket (cigarette‑lighter type)
2x USB power sockets
Quick release bellows (crawl through) (for tilt cab – service and maintenance)
Back‑up camera
Front wheel arch flares
LED under cab work light – switched
Premium sound system-Kenwood model #DMX905s
Premium speakers
Sound deadening in cab.
WeBoost internet signal booster
Mast steps
LED side turning lights
Wheel chock
External dip stick
New set of brake pads
Mud flaps heavy duty
New tires
A/C – D/C converter
BODY CONSTRUCTION
Camper chassis mounted to vehicle chassis w/Earthcruiser kinetic mount system
Domed molded structural foam insulated roof
Molded structurally‑insulated fiberglass walls & floors – 1”/2.5mm thickness
Molded structurally‑insulated fiberglass entry door w/dead‑bolt lock, incl. window W 19.7”/500m, H 11.8”/300mm
Molded structurally‑insulated fiberglass locker box doors w/2 compression locks w/key
5x Side windows (casement‑type, incl. privacy and insect screens) W 35.5”/900mm, H 15.75”/400mm
EXTERIOR FEATURES
Electrically‑operated entry stairs
Locks & latches – flushed or recessed
Electrically‑operated awnings, recessed into roof
External how/cold shower, 70.8”/1800mm hose, 1.77G/6.7L per min.
External purified drinking water faucet
External water faucet (locked and sealed)
Body side skirts, rear wheel arch flares, tool boxes
Air compressor with tank, hose Schrader chuck
ELECTRICAL – BATTERY SYSTEM / SOLAR CHARGING SYSTEM (12V)
3x 270 amp-hr 12V AGM house batteries (Total 810 amp-hr)
Fuso FG factory vehicle start batteries incorporated into electrical system
3x 125W solar panels: 375 W total (shatter proof, recessed into roof)
Standard solar control / mounting system
Inverter, Magnum 2012-20B – 2000W, pure sine wave – 110V
Shore power hook‑up receptacle plug adapter
110V power outlet – duplex, GFCI (rear locker area)
Accessory power – Anderson plug, 10 amp (rear locker area)
STORAGE
Locker box left hand side
Locker box right hand side
Tool box left hand side
Tool box right hand side
Pull‑out pantry
4x Under cook top storage drawers
4x Under sink top storage drawers
Interior drawers – anti‑rattle w/positive locking catches
2x Under bed storage drawer – 23.6” x 15.7” x 7.8” (584 x 381 x 195 mm)
2x Under bed storage drawer – 22.5” x 15.5” x 4.5” (558 x 381 x 178 mm)
Under bed storage – fit drawers, fit custom luggage, w/latched door 22’ x 25’ x 7” bottom; 22” x 15” x 7” top
Rear locker storage (total) Approx. 42”W x 18”H
Pass‑through storage for long items
INTERIOR
Command panel – main system controls
Fixed, full-size bed (Queen‑size) w/marine‑grade foam mattress (semi‑firm)
Easy clean fiberglass surfaces throughout interior
4-person dinette bench seats w/under‑seat storage, molded fiberglass, converts into 2nd bed w/cushions
Dinette seat cushions, grey leather
Swing‑away dinette table – converts into 2nd bed
Bedside cabinet – 5 drawers
Air conditioner (DC)
3x 110V power outlets – duplex GFCI
2x 12V accessory socket (cigarette-lighter type)
6x USB power sockets
Isotherm 12V DC refrigerator / freezer 130L / 4.24 cu ft, upright, stainless steel (works out of level)
Ceramic Webasto cooktop (uses diesel fuel from vehicle fuel tank) w/altitude adjustment, 102 BTUs per min., 3-6 fl oz per hour
Webasto Dual Top hot air and water heater – 200 cu meter / 7062 cu ft/hour air & 2.9G/11L hot water @ 158F/70C ambient temp. 5.5KW total heating capacity, hot water tank priority as required (6.42-22.3 fl oz, 200-650mm per hour)
Ducted warm air - drying room
Molded counter top with dual sinks
Kitchen faucet – hot/cold mixer
Purified water tap
Synthetic cutting board – fits over sink
Digital clock / outside temp gauge
2x fans recessed into ceiling
4x 6.5”coaxial speakers – marine‑type, ceiling mounted
Plumbing – internally routed, insulated where applicable
Rubbish bin – sealed, recessed, removable w/lid
Full‑height shower
Shower curtain – retractable
Shower head / sink faucet – hot/cold mixer, 1.77G/6.7L per minute
Interior head room 6’7”, 2006.6mm
Top of mattress to ceiling 44”/117.6mm
Bedside cabinet
Internal area 92sq’,
Thetaford cassette toilet #C402 (recessed when not in use) – 3.96G/15L, top flush 4.49G/17L waste capacity
LIGHTING
Driving light – 20” LED bar
2x LED lamps, interior cab – switched / adjustable
LED lamp, interior galley – recessed into roof
4x LED lamp, interior – bed area, reading, switched / adjustable
LED lamp, interior – bed area, recessed into roof
LED lamp – interior – dinette area, recessed into roof
2x LED lamp, interior – locker area
LED lamp, interior – shower / entry, recessed into roof
2x LED lamp, exterior – flood, sides mount, sealed, right side and left side
LED lamp exterior – reversing, standard, high mount
LED lamp, exterior – signal, high mount
LED lamp, exterior – tail / brake, high mount
LED lamp, exterior – work lamp, under cab, switched
FRESH WATER
High‑flow Whale fresh water pump; water system control / transfer console (interior mounted)
Hot water cycling system
2x Fresh water tank – main tank 43.5G/165L & 25G/94.6L
Secondary tank 25G/94.6L w/heater, both interior mounted w/level sender
Fresh water tank heater (exterior mounted)
Fresh water level monitoring (main control panel)
GREY WATER
Grey water tank – 20G/54.5L (exterior mounted) w/level sender
Grey water tank heater
Grey water level monitoring (main control panel)
GALLEY ACCESSORIES
Full set cookware, cooking utensils, flatware, plates, bowls, insulated mugs
Electric water kettle
Toaster oven
Rice cooker
French press for coffee
Seal-tight coffee container
Cast iron frying pan
1-quart pot w/lid
Large wok w/lid
Measuring cups
Serving tray
OUTDOOR STUFF
Eureka 13” round table‑top butane BBQ
Propane camp cooker
Outdoor cooking utensils
Bicycle rack -heavy duty for carrying E-bike
Optional for sale: E-bike -Specialized Turbo S w/cover
Cutters Deep Woods bug spray
Fly swatter
Insects screen in doorway
Collapsible basket
Collapsible bucket
Hammock
Cast iron firewood poker
Gravity chair
2 folding chairs
Folding table
LIVING SPACE
Electric blanket
Cargo storage net
Cordless vacuum
Dustpan and whisk broom
Medical kit
STORAGE
3 Front Runner stackable storage boxes
2 stackable milk crates
TOOLS
Full set hand tools
Level
Flashlights
Battery tester
Cleaning fluids
Saw
Shovel
Entrenching tool
4 sets of leveling blocks.
Heavy duty 50’ extension cord with 30-amp adapter with pigtail connector for shore power
50’ garden hose
Extra end‑of‑hose in‑line water filter
Tie wraps
Bungees
Recovery equipment
Levelling blocks
Tie down straps
2 sets Air-down valves, one for off-road, one for sand
mk216v
Der Chef der Fahrzeuge
Reed, any more pictures you can share besides the passenger side shot?
Does it have 2 or 3 AGM batteries?
Is the vehicle currently located in FL?
Any Duonic transmission issues/concerns?
Hi MK, 3 agm house batteries. The best shots of this vehicle are on the Earthcruiser website. Mine is identical to the vehicle on the website. This past summer there was a factory warranty recall on my transmission and it was replaced. I experienced no problems with it before or after the replacement.
Last January I completed the Baja 4000 rally and it went everywhere the jeeps and trophy 4x4s went. It is a beast.
I was going to take it around the world but realized it would take another 5-7 years. I'm 68 and there are too many other things I want to do while I'm still able.
You can turn the key and literally continue where from where I stopped. You would not need to buy a thing.
I live in Asia and am eager for a quick sale.
Hi, I do understand your reaction and never thought about how strange it must sound, but this is easily explainable.
I've been living in Asia since 1990, and in Thailand since 2000.
That's 30 years in total.
I had a motorcycle touring business there which I sold in 2007 and seriously started on my bucket list.
When I returned to America after Thailand I visited friends and family on the East Coast. I needed to buy a U.S. phone + get a US number and this I did when I was in Connecticut.
Item #1 on my bucket list was to spend an entire winter skiing and this I did in British Columbia.
The 2nd item on my bucket list was to buy a round-the-world vehicle to visit 6 continents and I decided on the Earthcruiser.
Earthcruiser Co. is based in Bend Oregon.
My first cousin, Phillip Resnikoff, lives in Oregon.
Since I have had no US address for decades, I rented an apartment on his property in Lincoln City, Oregon.
And then purchased the Earthcruiser from the factory in Oregon.
I have been travelling around North America for the last 22 months. You can read my numerous trip posts on Facebook-Reed Resnikoff. I invite all to read them.
My travels through all of N.A. ended in Florida, my last state in N.A. and that is why I ended up here. Why travel any further? So I rented an apartment in Wellington and plan on living here until I sell my Earthcruiser, at which time I will move back to Thailand. Once I am there I will work on bucket list items #'s 3 to 100, if I can live that long.
There are plenty of photos of Voyager 3 on my facebook page, but none of the interior because it is so small and tight, photographing it is difficult unless you have an extreme wide angle lens.
(My blog page is a work in progress and during the trip I realized that blogging was going to be too time-consuming so I switched to FB posts. This is why my blog page looks so unfinished.)
I will take some photos of my rig soonest and post them online, but the best photos of the interior are definitely on the Earthcruiser page and mine is identical to those photos.
I hope this eases your fears. This sale is 100% legitimate.
Craig Lathem
Craig Lathem
Reed and the rig are legit. Myself and several other EarthCruiser owners camped together at the 2018 Overland Expo in AZ. He was just getting under way at that point. I have been following along on his adventures.
DanoWall
