2015 Porsche Cayenne Diesel (958.2) - Premium Plus, Eurowise
jacobmatat
FS: 2015 Porsche Cayenne Diesel (958.2) - Premium Plus/Bose/Eurowise ~$20k in Recent Maintenance
108,xxx miles | Jet Black Metallic/Black Leather | Clean Title | VIN: WP1AF2A27FLA36465
Time to pass this along to someone who will appreciate what's been done here. This is my well-maintained 958.2 diesel with the Premium Plus package and major service items addressed in 2024-2025. If you know these cars, you know the 3.0L TDI is bulletproof when properly maintained, as this one has been.
Premium Plus Package
  • 14-way power comfort seats (heated/ventilated fronts)
  • Heated rear seats
  • Entry & Drive keyless (locking buttons on all exterior door handles)
  • Panoramic sunroof
  • Bi-Xenon with PDLS+ dynamic cornering
  • Power Steering Plus
  • Reversing camera with front/rear ParkAssist
  • Bose 14-speaker surround system (200W sub)
  • Rear side sunshades
Factory Options:
  • 19" Cayenne Turbo wheels
  • High gloss black window trim
August 2025 - Koncept Motorwurks
  • Oil and Filter Service
  • Remove & Replace Suspension Strut Assembly - both sides
  • Oil Cooler Replacement with thermostat, gaskets, hoses
  • Remove & Replace Timing Cover with seals, water pump
  • Air/Fuel Induction Service
  • Coolant Flush
  • Rear Differential Service
  • Transfer Case Service
  • Clean Intake & Manifold
  • Brake Fluid Exchange
  • 4 Wheel Alignment
  • Balance Wheels
August 2024 - Koncept Motorwurks
  • Full Vehicle Ceramic Coating
June 2024 - Koncept Motorwurks
  • Eurowise 2" Lift Kit with polyurethane upper control arms
  • Eurowise Front Bumper Install
  • Complete Rear Brake Job - pads, discs, sensors
  • Complete Front Brake Job - pads, discs, sensors
  • Brake system grind-in procedure
  • Mount/Balance 4 Wheels/Tires
  • Falken Wildpeak Trail 255/55/19
  • Thule Caprock roof platform
April 2024 - Porsche South Bay (Engine-Out Service)
  • Engine removal and reinstallation
  • Timing cover reseal and crankshaft sealing ring
  • Upper chain housing cover reseal (Bank 2)
  • Turbocharger seals and cylinder head cover seals
  • Injector seals replacement
  • Coolant pipes replacement and full system flush
  • Vacuum coolant bleed
  • Brake caliper refinishing
  • 4-wheel alignment
California car with clean emissions. Passed CA smog emissions summer 2024 with all systems functioning after the major engine service. Non-smoker vehicle. No pets. Clean title. Garage kept.
The diesel Cayenne is the sweet spot if you want torque, fuel efficiency, and capability. The recent service investment addresses common aging items on the 3.0L TDI, plus suspension and cooling system refresh.
The mods are completely reversible if you want to return it to stock, but honestly, the 2" lift and AT tires transform how this thing handles trails and snow while maintaining excellent on-road manners.
Located: Woodland Hills, CA
Price: $38,000
PM me with questions, to schedule a call or a viewing. Not interested in trades. More photos, Carfax, and records available on request.
evo3gsx
Can you provide additional pictures? How long have you owned the truck and do you have the carfax? Do you have the record for the engine out service - would like to know if the upper oil pan gasket was replaced. Also, is the lift kit just a spacer lift or full coilovers?
jacobmatat
  • I will take additional pictures today. Is there anything in particular that you'd like me to photograph?
  • I've owned the Cayenne since May 2024. I've DM'd you a link to the Carfax.
  • I have the record for the engine out service. I've DM'd you a link to the service record.
  • Re: Eurowise: I opted for the lift kit. The factory suspension was plenty adequate for my needs.
sunnyaz
