dzrtdave
Supporting Sponsor: Turtleback Trailers
This rig was built for the Overland Expo this year. Adventure Driven has had it out doing some marketing through the summer season. Our 2016 models are now coming out so we have an opportunity for you to get an almost new Turtleback and to save a few bucks.
It has a full factory warranty and is loaded with these options:
• Full Steel Trailer 2x3 Perimeter Box Frame, 3500# stub Rubber Torsion axles 2750# Springs, 10" Electric Brakes, 16" Steel Wheels, 265/70-16 AT Tires, Forward and Aft Receiver Hitch on Frame, Bedliner Coated Chassis, 0.050" White Aluminum Skin, 2 Side and 1 Rear Compartment, Doors w/ Matching Keys, LED Lighting, 20# Propane Tank with Stainless Steel Bracket, Deka Group 24 AGM Marine Battery in Box with Blue Sea Fused Terminal Block, Blue Sea Systems® Marine Grade Electrical Components, 4 Rail Cargo Bar Roof Rack, 2000# Swing Away Tongue Jack with Foot, Safety Chains, 7 Way Flat Trailer Plug Wired to: Running, Brake, Turn Charge Line & Trailer Brakes, Interior Lighting in Cargo Area and Kitchen, 42 Gallon Fresh Water Tank Food Grade, BPA Free Construction, Flowjet 12v Demand Water Pump, Atwood 6 Gallon DSI Water XT Heater, Exterior Shower, Baltic Birch Pantry Drawer in Kitchen Area, Baltic Birch Slide Out Kitchen with 2 Drawers, 2 Burner Wedgewood Stainless Steel Stove with Stainless Cover by Atwood, Stainless Steel Sink with Hot & Cold Faucet
• UCF Spare Spindle/Trailing Arm
• Upgrade to UCF Torsion Axle
• 48"x32" Nose Box, 45" Side Box, 25" Side Box Our Storage Box Set are constructed in house using CNC Laser cut aluminum. Then they are CNC bent to insure the perfect fit. Our welder TIG welds them together then they are powder coated in and out. We finish the assembly with 1/163 stainless rope to hold the doors at a 90 degree for additional table space. We line the door with Baltic Birch inserts and seal the doors with 3/8" rubber bulb seal that is connected with a steal re-enforced pinch welt. We use polished stainless like keyed latches
• Tailgate - Includes 18x36 brushed stainless steel fold down table, spare tire mount, spare idler hub with greased bearings, Turtleback Trailers Rotopax dual mount
• 2 Battery Electrical System Upgrade - Includes Blue Sea Battery Disconnect, Blue Sea 6 Circuit Fuse Block, 6 Amp Marine Battery Charger (Shore Power), 10 Amp Solar controller with Voltage Meter.
• Pure Sine Wave Inverter Package: Includes a Blue Sea Battery Disconnect, Blue Sea 150 Amp Breaker, 1000 watt Xantrex pure wave inverter
• 2nd Battery - Deka AGM 79 Amp Hour Battery, Battery Box, Blue Sea Fused Terminal Block
• Picnic Table Mount - Double Table
• Custom Color Powder Coating - Bengal Silver
• Stainless Awning Bracket - Pair
• Foxwing Awning
• Additional charging port with 1 Blue Sea Marine USB dual port and 1 Blue Sea Marine Hela plug on stainless backing plate
• Grill Tank w/ Bracket
Dave
Turtleback Trailers LLC
dave@turtlebacktrailers.com
www.turtlebacktrailers.com
• Foxwing Awning
Dave
