2016 Mercedes Benz Metris Camper
SquirrelZ
$43K
Located in Anchorage, AK
Miles- 27,039
This is a very well equipped 2016 Metris cargo van converted into a fully insulated camper with a Webasto heater and a galley. It has just about every safety and comfort option that MB offered for the cargo van in 2016. I'm the second owner and did the camper conversion. The title is clean with no accidents.
Van Specifications and Equipment
2.0 liter, 4 cylinder turbo charged gasoline engine
Estimated EPA mileage is 21 city/24 highway
7 speed automatic transmission with manual shift paddles
Rear wheel drive
225/55R17 Tires
18.5 gallon fuel tank
Full sized spare tire
Tire pressure monitoring system including the spare tire
Roof Rails
2" Trailer Receiver (Factory installed), 4960 pounds towing capacity
Backup Camera
Navigation system
Cruise control
270 Degree Opening Rear doors with washers and wipers
Antilock brakes, electronic stability control, front and side airbags
Driver Efficiency Package (rear view camera, fog lights, cruise control and navigation system)
Cold Weather Package (heated front seats, heated rear view mirrors, heated windshield washer fluid, heated rear windows, electrical booster for heating)
Driver Comfort Package (fully adjustable ergonomic seats for driver and passenger, heated seats)
Multi-Function Wheel/Display Package (steering wheel controls and enhanced gauges)
ECO Start/Stop Package
Active Safety Plus Package with Active Parking Assist (collision prevention assist, blind spot assist, crosswind assist, lane keeping assist, automatic wipers)
Camper Modifications
Swivels on both seats front seats were made by Scopema/RIB
Two CR Lawrence sliding windows in the rear
Fantastic Fan in the ceiling
Noico 80 mil sound deadening mat used on the roof from the windshield to the rear doors as well as on the walls and floor in the rear of the van
R Max 1 inch insulating foam used on the roof from the windshield to the rear doors as well as floor in the rear of the van. The rear walls have from 1 to 4 inches of insulation.
Textured white plastic paneling used on walls and ceiling
Electrical
Rigid E Series 10 inch light bar for night driving
Trojan 205 AH AGM battery for house power
Itek 300 watt 60 cell solar polar panel
Blue Sky Energy Solar Boost 3000i MPPT solar charge controller
Sterling Power BBW1212 Battery to Battery charger
Magnum 1000 watt pure sine wave inverter/charger with remote panel and battery monitoring system with 120 volt plug in for recharging from the grid
Blue Sea master switch to isolate the Trojan battery from the fuse panel
Blue Sea 12 circuit fuse panel and Blue Seas 4 circuit sub panel
Bussmann CB185 Type III High Amp Switchable, Waterproof, Flush-Mount Manual Reset Circuit Breakers for the solar panel, inverter and circuit panels
LED strip lights along both ceiling edges, both with rheostats to control brightness
LED ceiling lights, 8 lights on 3 circuits
Two 120 volt outlets (1 in the drivers seat base, 1 in the electrical panel)
Three combination 12 volt/USB charging ports (1 in the passenger seat base, 1 in the electrical panel, 1 on the rear passenger side wall)
One 12 volt outlet in the passenger side rear corner
One USB outlet in the passenger side rear corner
Galley
Corian solid surface counter top
Dometic 2 burner propane cooktop/sink combination with glass lids
Fold down faucet (12 volts, switch activated)
Two 5 gallon fresh water jugs, One 5 gallon gray water jug
Electrical switch to turn the propane solenoid on and off
11 Pound, 2.6 gallon propane tank in a clear Lexan locker, vented to the exterior, with pressure gage and 2 shut off solenoids (LPG detector and galley on/off switch)
Galley cabinet made with prelaminated 1/2" Russian birch 7 ply plywood
All doors and drawers are mounted with Blum hardware so they are all very easy to remove and replace
Southco stainless steel latches for doors and drawers
The rear seat/bed is made with 3/4" prelaminated plywood. It has 3 positions- flat for travel; the seat position allows for different angle adjustments of the back rest; or extended on into the bed position using drawer slides rated at 500 pound. The bed is 45" wide x 80" long. The entire unit can be easily removed by taking out the drawer and loosening 4 nuts. It is NOT designed or intended for carrying passengers when driving. The cabinet is designed so that a Scopema Neptune 3P seat will fit, which would allow for carrying 2 passengers as well as having a fold down bed.
Safe-T-Alert LPG/CO detector with automatic LPG shutoff solenoid in the propane locker
L Track tie down bars used extensively in the walls and floor to secure cargo, clothes lines, Blue Tooth speakers, etc.
Circular L Track attachment point hold the ceiling in place and provide additional place to connect light weight items such as speakers or clothes lines
Coat hooks on both walls in the rear of the van
Heatshield reflective window screens
Mosquito screens for sliding door and both front doors
