2016 Ram Power Wagon Thuren/Fox
tclason
Houston, Texas
$39,900 firm.
91xxx miles.
120,000/5 year transferable BUMPER TO BUMPER warranty - buy with confidence
6.4L Hemi.
Thuren 3” Extended Travel Suspension Lift
FOX shocks.
WARN 12,000lb winch.
37”x12.5” Discover AT Tires
Vision Alloy Wheels.
KING steering stabilizer.
POWERSTOP drilled and slotted rotors with performance brake pads.
Alpine Sound System 7” sub and amp
Suspension:
Less than 20k miles of use!
Thuren 3” Extended Travel Lift. Custom Thuren springs front and rear. FOX long travel shocks. KING steering stabilizer. Thuren trackbars front and rear. Extended swaybar links. Extended ultra soft bumpstops. Heavy duty steering link and steering brace.
Factory:
6.4L Hemi V8
Fox Shocks and Thuren Springs 3” lift
Front and Rear electronic locking differentials (full lock not limited slip)
WARN 12,000lb winch
4-Wheel High and Low (dual transfer case)
4.10 low gear ratio
Ram tow package and Tow Mode
Alpine speaker system, base and amplifier
Power Wagon skid plate underbody protection
Full factory spray on bedliner
30 gallon primary tank
Mopar factory accessory bed rails and tie downs
Lockable RAM BOX storage
Electronic disconnecting swaybar
Projector Headlights (high and low) with LED running lights
Rear parking sensor
Rear backup camera with trailer assist
Ram floor vault storage
3 Keys
Performance Modifications (all less than 10,000 and 1 year)
Thuren 3” front and rear suspension lift Extended Travel (Fox racing shocks, Thuren soft rate coils, Thuren adjusted trackbar/panhard bar and swaybar links, King steering stabilizer, Thuren super soft Boogie Bump stops)
37” Discover AT tires
Vision Alloy Wheels
Power Stop front and rear drilled and slotted break kit and pads (less than 2,000 miles, ZERO noise)
Dodge Offroad steering brace and bearing
Truxedo bed cover
Husky bed box
3M Ceramic window tint
Full coverage 2” fender flares
SlickRope
If I was in the states I would defiantly be considering it. GWLS ....someone will come along and pick it up. Especially with truck prices right now.
Goldenbora
