2016 Specialized FSR Expert Carbon 6 Fatties - Lakewood, Ca
wesel123
It's with a very heavy heart I'm selling one of the best Mt. bikes I have ever owned. Just don't have the time to ride this and my 1150...the 1150 wins most of the time.
I've ridden it about 5 times and nothing crazy. I changed out the bar to a Specialized Carbon S-Works mid rise 780mm with awesome Oury grips. Also included are a pair of Cromag Scarab flat peddles. The Brown WTB seat I'm keeping the black seat shown in the picture will be installed shortly.
Sold.. Thanks for looking
Specifications
Release Date 2016
Price $6500
Travel 135
Rear Shock FOX FLOAT Factory DPS, AUTOSAG, Rx Trail Tune, Kashima coating, 197x47.6mm
Fork FOX 34 Plus Performance Elite, 150mm travel, 3-position compression adjust, tapered steerer, 51mm offset, 15mm thru-axle
Headset Hella Flush, 1-1/8" and 1-1/2" threadless
Cassette SRAM XG-1180, 11-speed, 10-42T
Crankarms Custom SRAM S-2200, carbon, PF30 spindle, 28T, direct mount
Bottom Bracket SRAM, PF30, OS press-in bearings
Rear Derailleur SRAM X01, 11-speed
Chain SRAM PC-X1, 11-speed
Shifter Pods SRAM X1, 11-speed, trigger
Handlebar Specialized, 7050 alloy, 8-backsweep, 6-upsweep, 10mm rise, 750mm, 31.8mm
Stem Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
Grips Specialized Sip Grip, light lock-on, half-waffle
Brakes Shimano Deore XT
Hubs Roval Traverse
Spokes DT Swiss Revolution
Rim Roval Traverse 650b, alloy, disc, 29mm wide, 24/28h
Tires Specialized 6Fattie Purgatory Control, 60TPI, 2Bliss Ready, folding bead, 650bx3.0", Specialized 6Fattie Ground Control, 60TPI, 2Bliss Ready, folding bead, 650bx3.0"
Seat Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
Seatpost Command Post IRcc, remote adjust SRL lever, 30.9mm
Compare to other All Mountain/Enduro/XC
wesel123
d3APeO6eIf8Z3Sq9OygrWQya4PmiS1y2K79icCTnZNht09E3bLBHVpmIDKuKgmBI6tlAyB6v7HPjGwoy70HdLoS4Es-z44CrMDCHorrttUAwKwvUAlRvjKRK3G6tXXqyVGtOt5y5cAwshY7w2Z0q9FpqfNWKKQtkUsVtpJEmZNb2WZFbajAbHk8HHayE-AE8msohzSzHqhCupZ97HTcHfAZZiIdHtoljkmx-SbUS4dF2Yv0HG8cc6LwqDcDdMsRrIuv7XNtGo73jceiDoUDxLfVDgGmr29jxF6liT62B436ZXYBW4UA-Kj-0Shfll7bPHt1LfIUBNq0B2dDmxp_sL6I2IknLSI0B45-TKrft5QvuWrP2jUJt_vK3VMRETm-5xVjqRIvq0j_KLO7VXK8LEnI1hOG91m52mvq2XG7e_Lso5MCs6Z1eI7KYzoRrsbO7ICA8dbNq2-lwGLFpakY1QyuebU9XYL8YA96NI-eDqVVwE0hdzEuf0WQs0gxdB9PGmFlgwypCho7qE2WELc_n1wOA2pJH4uBZIDOtNPLxOiC8lcptGOXvskQCsLwIPzUm7SZJJINooquGpsmYbyAaqT0kCPUUyxb9y20YuLB-eELspggziAncg_e6J5_kJy6Vu8WGcy0p0JS2XEz9mij3rofKziUeJqFN=w3775-h1835-no
AF1QipNDINoY7bpaV09zqZmnqXw8DpjeLi89vqafFLuo
wesel123
Yep its Carbon-fiber. According to Specialized web site it shows 29 lbs. Could be plus or minus a pound as I changed the stock aluminum handle bar to an S-Works Carbon bar and added the Cro-Mag peddles.
iStan814
