2017 Cirrus Camper $36,900
DBR2
2017 Cirrus 820 Truck Camper, for sale.
The camper is in like new condition, is housed in a climate-controlled Shop, only had 3 short uses since purchased new 20 days total.
The camper has had many modifications to make it off grid capable.
3-200 watt monocrystalline solar panels (600 watts total) have been mounted, Victron smart Mppt controller (bluetooth) and 600ah of LifePo4 batteries on board.
Victron Smart BMV 712 with Shunt, bluetooth monitoring
A Xantrex, inverter charger 2000watt inverter/80amp lithium charger, integrated with the system.
40amp DC to DC Renogy Charger, to allow a controlled charge to the batteries while driving down the road, protecting the most alternators from overheating.,
A Micro-Air EasyStart was installed on the Mach 8 9200BTU air conditioner to let small generators start the A/C with ease. The A/C also had a Bluetooth interior A/C diffuser installed allowing auto run and temperature change from your Bluetooth phone.
Generator and shore power transfer switch hard wired to allow auto switching to the generator if shore power is interrupted. A progressive industries power surge protector has been hard wired into the electric system as well, no concerns about someone stealing the surge protector off the power pole at a campsite.
2500 fuel injected Generator on board, with extended fuel tank, altitude is no longer a concern with fuel injected generator, it will have less power as you move up in altitude, but will not burn rich, fuel injection corrects for altitude. Less than 3 hours on generator, never had to use the generator, I just start it and run it or exercise it as they call it.
I removed the 30" wide microwave that needed 120 AC to run the range hood fan, It was replaced with a convection oven microwave, now allowing an oven as well. I installed a range hood that now runs off of 12vdc and has a variable speed fan to control the air volume needed.
I installed a set of small fans to allow the removal of air from the camper to help control air exchange as well.
The camper is well suited for camping off the average campsite, to places that or more remote and allowing extending stays.
The camper is in like new conditions, the 2017 models have larger water capacity and more drawers than the newer models, cost cutting as time moves on.
318 458-7096 You can txt or call.
  • 2017 Cirrus 820 modifications.pdf
tbnd88
