This adventure RV is immaculate and I purchased it brand new and it has only been used a handful of times. The most impressive aspect is the Blue TECH turbocharged diesel with with less than 20,000 miles. This RV drives like an SUV, yet offers plenty of space and options. There is exceptional ground clearance and is just under 24 feet in length. Sleeps 6 with ample storage inside and out. The bathroom and shower is wonderful as is the premium queen bed. What's really nice is the dining table and bathroom can be accessed without the slide being out. I just had two new coach deep cycle batteries installed, a new Mercedes driving battery installed and the unit is solar ready. There is an outdoor propane quick release adapter on the right side rear with a portable grill. No need to worry about carb cleans on the onboard Onan propane generator that is super quiet and efficient. Want to live year-round in it, the Arctic Package keeps the tanks from freezing, the heat pump allows for additional gas or electric heat and the block foam keeps the unit well insulated. Need to pull a trailer, no problem with the Premium Camping Package that includes a Class III Receiver. Don't forget the outside shower and sound system. The Mercedes Sprinter chassis with the Helwig anti-sway system makes this unit driveable in high wind conditions.
I can be reached at Kim Wallace 503-930-4294. If you do your homework you won't find a better deal on this type of adventure vehicle. In fact, here is the name and contact info of Woodard Mobile RV in Salem, OR who has cared for this unit for the last year or more. Bob Woodard cell# 503-713-8359 or office# 503-341-5868 email mobile@woodardrv.com.
Adventure ready with:
- Battery disconnect switch
- Water heater bypass
- (2) Deep cycle coach batteries
- “Easy Access” battery in step-well
- 30/50 Amp service with power cord
- 60 Amp Progressive Dynamics converter
- 6 Gallon DSI gas/electric water heater
- 30,000 BTU furnace
- Satellite/cable connection
- 13,500 BTU ceiling ducted roof air
- 3.6 KW Onan LP generator (propane)
- Automatic generator transfer switch
- Water filtration system
- Arctic Package (12V tank heaters)
- 15K BTU A/C with heat pump
- Carbon Monoxide, LP and smoke detector
- Winegard digital antenna
- 1.5” Aluminum framed laminated sidewalls
- Superlite composite substrate
- Gel Coat exterior fiberglass
- Block foam insulation
- Power patio awning with LED lights
- Slide-out awnings
- Fiberglass roof
- One-piece fiberglass front cap
- LED exterior lights
- Stainless steel wheel liners
- Valve stem extensions
- Roto-cast storage compartments
- Driver side security light
- Fiberglass running boards
- 110V, GFI protected exterior receptacle
- Tinted frameless windows
- Heated, remote exterior mirrors
- 4,200 Lbs. hitch, 7-pin connector
- Roof ladder
- Power entry step with motion sensor light
- Stabilizer jacks (2-point)
- LP quick connect
- Full body paint
- Outside shower
- Outside 12V LED TV
- Black tank flush
- Fresh water 35 gallons
- Gray water 32 gallons
- Black water 32 gallons
- Added protection with EcoRV treatment--ExteriorShield and MicrobeRepel
- Platinum Coverage Extended Warranty
- and more!
Thank you,
Kim
