Patriot Campers only imported the X2 for 2017 and 2018. This was the smaller version of the Patriot Camper series of trailers. This trailer is light and nimble, carries enough gear and agile enough to get into remote locations. Smaller footprint and can be pulled by smaller SUV, as it is only 1500 lbs.
Get all the benefits of the Larger Patriot X1 in a smaller more affordable package!!
The X2 is a small and capable overlanding camping trailer which gives you a blank canvas for creating you own experiences.
Within this rugged package you are able to cook excellent meals, store provisions in the pantry and included 50 qt fridge, wash up with the 20 gal of on board water storage. This trailer can go anywhere you want to take it with fully articulating hitch, axle-less suspension, and 33 inch tires.
The Rhino Rack serves as an excellent platform for mounting anything from bike or kayak holders, using as a tray for lashing gear to, or as surface to mount a rooftop tent.
The 270 degree 8 foot Rhino Rack Batwing awning provides shade from the driver side of the trailer to the rear. Included are two tapered additions that can either act as walls or extra shade. Also included is a Front Edge insert to square off the end of the awning.
The kitchen on the passenger side has storage for all your cooking gear and utensils as well as a drawer for spices, coffee, etc. The Bromic stove works well even in strong winds.
Stay out for days, weeks even, with ample gas and water storage and the ability to recharge the battery system using solar or vehicle connections. The Redarc Manager allows easy management of all electrical. Go anywhere in a trailer as capable as your vehicle.
Registration good until 9/25
Features:
- Power system:
- 200AH of Gel battery
- Redarc management
- Solar charging capable and available via SB50 connector
- Shore power connection
- Vehicle charging capable via SB50 connector
- Built in lighting in each compartment and rock lights
- Built in bluetooth radio with speakers
- 2 external 12 volt sockets at rear
- 1 internal 12 volt socket and 1 pair of 5v USB outlets
- Water system:
- 85 liters of water storage (22 Gal)
- Integrated water pump with
- 2 quick connections for water access
- Water fill and equipment storage compartment
- Pop out sink for rinsing and cleaning
- hose and 2 spray nozzles for water system
- RV style water level indicator
- Gas/Cooking/Food:
- 2 x 10lb gas bottles
- Bromic 2 burner 10,000 btu stove
- Weber Q1000 gas grill
- Pull out stove drawer
- Rear slide with:
- Large sealed dry pantry
- Dometic 50qt Fridge/Freezer
- Storage
- 4 main storage compartments, all lighted
- Front "Garage" compartment:
- Storage for Water heater
- storage for other quick access items related to towing such as leveling blocks and gloves
- Kitchen Compartment (driver's side):
- Main electrical switch panel and REDARC Manager interface
- Radio
- Stove
- Storage Drawer
- Large, full length storage compartment (passenger side)
- Excellent for storing clothes and sleeping gear
- Can fit 6 Frontrunner Flat Packs
- Rear storage compartment
- Full length of trailer
- Contains fridge and pantry slide, battery compartment
- Remaining space for other storage items
- Rhino Rack Pioneer Platform
- Large rack platform for carrying gear or RTT
- Includes 4 stainless loops for tying down equipment
- Can mount a tent to the platform
- Two "wet" lockers on the rear, great for storing wet and/or dirty gear such as shoes.
- Miscellaneous:
- CVT Tents Mt Rainier with Annex (Orange)
- Rhino Rack 8 foot, 270 degree Batwing awning, 2 wall kits, and 1 triangle kit.
- 33" tires on 16" wheels and Toyota pattern hubs 6x139.7
- Patriot Campers XCruise fully articulating axle-less suspension
- DO35 Cruisemaster fully articulating hitch and 2 hitch pins (can include drop if its the right size for you)
- Electronic brake control system as well as manual brake.
- Texas registration good through Dec 2025
- Rear 2 inch receiver, great for bike rack.
- Spare tire
- Bottle jack and tire change setup
- Fire extinguisher
Features:
- Power system:
- Redarc management
- Water system:
- Gas/Cooking/Food:
- Rear slide with:
- Storage
- Radio
- Stove
- Storage Drawer
- Miscellaneous:
- Spare tire
- Fire extinguisher
