sam_13
2017 Toyota Tacoma TRD Off Road Double Cab Long Bed (6 ft) with OVLND Camper 3.5 Liter V6 6-Speed Automatic Transmission and 4WD
Interior:
Additional Parts Included, but not installed
- Exterior Color: Silver Interior Color: Graphite with GunMetal (cloth)
- Original owner; Title in hand
- Mileage: 85,XXX
- Asking Price: $55,000 OBO for the truck and all parts listed below.
- Service: On schedule or early maintenance was consistently performed by the dealership while under warrantee and by RSG Off Road shop after the warrantee expired. All fluids have been aggressively replaced including differential at time of 5.29 install, after break-in, and again the following season to ensure excellent break-in and protection. The truck has been well cared for and kept clean. There is some minor pin striping as expected but no body damage or rust. The vehicle was built to be the ultimate compromise between a rock crawler, road-tripper, and bear-proof camper to spend extended time living in remote areas. We intended to drive the truck until the wheels fell off, but our adventure plans have evolved so we are transitioning into a full-size truck.
- Serious inquiries only.
Interior:
- Expedition Essentials Dash Mount and Ram Balls
- Console Vault center console safe
- WeatherTech Floor Matts
- Rear Seat Delete (rear seats included and in brand-new condition)
- Rago Fabrication Center Console Molle Panels
- Sun Roof
- Custom Toyota Grille
- WeatherTech In-Channel Vent Visors
- Cab-mount chop to clear 34’s
- Ditch light hood brackets
- Bed rug
- Carpeted bench seats with storage
- Pop & Lock Power Tailgate Lock tied to factory locking system
- 3.5 Liter V6 6-Speed Automatic Transmission and 4WD
- Intentionally unmodified to maintain Toyota reliability
- S-Tech Switch Systems Electrical box
- ARB dual air compressor (mounted in engine bay, activation routed to S-Tech)
- ARB Differential Breather Relocation front and rear
- Diff Drop
- Nitro 5.29 Gears
- Factory rear electrical e-locker (along with other TRD OD features - crawl control, terrain selection)
- ARB front air-locker
- RSG Custom Sliders (steel) with rear kick-out
- Steel Skid plates - front, mid, and rear (transfer case, gas tank, rear differential)
- C4 Fabrication Hybrid Front Bumper - flat black powder coat, Full Height Bull Bar, Side Tube Gussets, Center LED 30” Bar Cutout
- C4 Fabrication Overland Series High Clearance Rear Bumper System - Satin black powder coat, Single Full Length Swing Arm (Passenger Side Pivot), Spare Tire Carrier, 11lb propane cylinder and mount, Dropdown Camp Table, Side Protection Tubing, Factory Rear Camera Relocation Mount, Reverse Light Cutouts, Parking Sensor Hole Cutouts, License Plate Mount
- Smittybilt X20 Winch (10,000 lb.) with synthetic line and Factor 55 Hawse Fairlead, Rope Guard & FlatLink E Shackle Mount Assembly
- Fox 2.0 Suspension 2.5 DC Reservoir Front and Rear Shocks Kit
- ARB Heavy Duty Add-a-Leaf Spring
- Dirt King Fabrication Ball Joint Upper Control Arms
- (5) Method 704 Matte Black Wheels with Bead Grip Technology (17x8.5" 4.6” backspacing)
- (5) Toyo Tires 285/70r/17 Open Country A/T III
- 30” Baja Designs Amber Light Bar
- Baja Designs Squadron Pro pair with Amber Wide Cornering lenses mounted on front bumper
- S2 Pro Flush Mount pair with White Spot lenses mounted in rear bumper
- S2 Pro Ditch Lights mounted on hood brackets
- OVRLND Mid-size Camper for 6ft bed
- Anodized SILVER Aluminum Skins
- 270 Degree Rear Barn Doors
- Left and Right Flip-Up Side Hatch with Gas Strut Lift Support
- Awning trim added on both sides of the camper. Commonly used with Keder rope.
- Awning channel added to the rear of the camper right over rear door. Awning channel is commonly used with Keder rope.
- Rotopax Mounts
- MC4 positive and negative connector solar port added to the roof. Wired back to the driver's side rear of the camper for easy solar panel hook-up. (10AWG 600V wire)
- Gas lift struts to aid in opening and closing of camper top
- Third brake light added above rear door
- Rago Fabrications Bed Channel Stiffeners
- Rear Tire Maxtrax mounting bracket (MaxTrax not included)
