2018 Crux 1600 Expedition Trailer
Nomadic52
This 2018 Crux 1600 weighs in at only 1,800 pounds. In excellent condition. With the independent suspension and articulating hitch, this unit can go anywhere your vehicle can tow it! The Crux 1600 has an outside kitchen with a Dometic cook stove and sink. The unit also has an 18 gallon water capacity. Rear frig slider that will fit most 50qt refrigerators. Comes with a Waterport solar shower that mounts to the rear receiver hitch. Also a new 20 pound propane tank. It’s incredibly capable Offroad and will go anywhere your tow vehicle can pull it. Tons of storage in sliding lockable drawers.
This unit comes fully loaded with a huge annex room that covers the kitchen, a 100 watt soft folding solar panel that keeps the AGM battery charged up when you're off the grid.
Trailer dimensions: L 11’6” x W 5’5” x H 4’9”
Tongue Weight: 220lbs
Weight: 1,800lbs
GVWR: 3,300lbs
Suspension: Independent suspension with heavy duty springs and gas charged shocks
Brakes: 10” electric brakes with a hand brake on the draw bar
Safety chains": Dual drawbar safety chains
Chassis: Heavy duty, off-road, galvanized steel frame
Rims and tires: 15” alloy rims, six bolt pattern and 31” x 10.5” Hancock Tires
Connection Plug: Standard 7-pin connection plug
Water Tank: Stainless Steel 18 Gallons with alloy skid plate
Storage: All storage doors have air-tight, waterproof seals and locks
Jerry Cans: Two jerry can holders on drawbar
Stabilizer Legs: Four heavy duty, adjustable, lockable legs
Lights: LED lights throughout trailer, in crucial locations: chef’s galley, electrical panel, refrigeration chamber, LED tail lights
Bed Size: L7’1” x W5’7”
Electrical: 100A/H deep cycle battery, overload protection, four 110V outlets, two 12V outlets, 1000w inverter. Battery is charged by your vehicle when 7 pin style plug is connected. Shore power and solar power.
Coupler: 360 degree poly block coupling
Trailer Jack: Heavy Duty Swing Up 10 inch Jockey wheel
Chef’s Galley: Slide out stainless kitchen with Dometic two burner propane stove, sink and electric water pump
Tent: 15oz Coated Canvas tent and ones with an additional extra large annex room.
Kept inside and under cover. Ready to load up food, water and gear for overlanding adventures.
Call 720-560-1178. If this ad is posted it’s still available. I won’t answer texts or emails, only phone calls.
