2018 F150 3.5 Homebuilt Aluminum Flatbed Pop Top Camper - 40k Boise,ID
Jsweezy
Hello Forum,
I have decided to sell my F150 with a homebuilt flatbed pop top camper.
Build thread for the flatbed and camper is here - https://forum.expeditionportal.com/threads/jsweezys-f150-homebuilt-flatbed-truck-camper.242504/
Truck stuff - CLEAN TITLE IN HAND
2018 F150 3.5l Ecoboost w/ 87k miles
Brand new brakes all around
new front wheel bearings and 4wd Vacuum hub thingys
Fox Front coilovers that lifted it some
Custom rear springs from Boise Spring works
Fox shocks in the rear
Just did the Cam Phaser replacement thats common on this engine ($4500 later...)
17x8.5 Method MR703 BLK PAINT with matching spare
315MHz Tire Pressure Sensor
LT275/70R-17 BFGoodrich All-Terrain T/A KO2 E
Electronic Rear Locking differential
Theres probably stuff im missing but thats the main goodies...
Camper stuff -
Length at floor is 86", width at floor is 79", Height when up is ridiculously tall, its 40" from the bed to the roof inside so you can sit up in bed.
Weight is somewhere around 1300 - with the boise springs it rides better with the camper on.
All Aluminum constructed frame with 1.5" square tubing
Purple Foam insulation throughout
Dometic DZ95 fridge
Full Victron setup with dc-dc charger, shore power charger and solar panel on top
2 -100ah self heated battleborn batteries
Diesel heater with quick connect gas tank
Rear bench seat but otherwise open floor plan for maximizing space for toys.
Linear actuators in the pop top from firgelli automations with the control box that allows them all to lift at the same rate.
There is also the normal style lift brackets inside so if something fails with the actuators you can just unbolt them and lower it normally.
Top is made of sunbrella firesist
Electric jacks for loading with a remote so all you have to do is mount them and use the remote to lift off of the truck body
Quick release mounts on the side so you don't have to worry about using bolts through the floor.
Its not perfect but I think its also priced accurately. Feel free to ask questions!!
If you dont want to use the forum chat, feel free to email me at TheJoshSweeney@gmail.com or call/text at 503-941-8661.
Jsweezy
Interior -
Jsweezy
Oh I forgot to include that if you want it, I will include this canvas top I made for the truck for when I dont have the camper on as well.
sunnyaz
