2018 Jeep JKU - Overland Build! Only $33K
nn0202
2018 Jeep Wrangler JK Unlimited Sport S 4x4
58,642 miles
VIN: 1C4BJWDG1JL845004
Lien title
Second owner. Purchased the Jeep in February 2022 from a dealer in Arizona. It had 23,066 miles on it when I purchased it
Asking just $33K for this awesome Jeep
Black clearcoat exterior
Black interior
3.6 Liter V6. Gas engine.
4 wheel drive
5 speed automatic transmission
Pro Comp 3.5 inch lift kit
Bilstein 5100 shocks all the way around (installed June 2023)
Adams driveshaft (installed June 2023)
4 BFG MUD TERRAIN tires — T/A KM3 35 X12.50R17 LT 121Q E2 RBL (purchased new from Discount Tire in November 2022). Plenty of tread left. Barely touched dirt, all local road/highway miles. Tires rotated frequently as well.
Brand new General Grabber spare tire
V Rock Wheels
Auxiliary light bar and light pods
DV8 front bumper
Badland ZXR 12,000 winch — with remote (never used)
Smittybilt Atlas rear bumper with tire carrier, jerry can, farm jack mounts
Farm jack (never used)
Oedro Rock sliders
Oracle Rock lights under all 4 wheel wells
Off-road fenders
Aggressive grill cover
Smittybilt Neoprene front and rear seat covers
All weather floor mat set (Mopar OEM)
Routine oil changes every 2-3K miles
Cabin air filters and wipers replaced as needed
Coolant flush and thermostat replaced in October 2024 (Mopar parts/fluid only)
Supportive seats
Power accessories
Air conditioning
Full color touchscreen infotainment system with Bluetooth
USB/Aux inputs in front and rear
Although I built this Jeep to be a weekend warrior or to live/work out of full time, I barely ever used it for camping or off-roading. This Jeep has NOT been beat up on trails and I only went camping for maybe 8 nights total with it, if that.
Priorities in life changed and never really had the time to go on the adventures I wanted to (yet). This Jeep has been my daily driver since I purchased it in 2022, and I work from home, so I don’t drive it much on a day to day basis. Mostly highway miles.
ALL the below overlanding/camping parts were purchased NEW and professionally installed in August 2023. All these parts are in perfect condition and barely used. In total the overlanding/camping setup is over $6K in parts and another $2K+ in labor.
Kickass Control Hub
This thing is awesome. Check out the link below to see how it can charge all your devices.
https://kickassproducts.com/collections/batteries-systems/products/control-hub-with-no-dcdc-charger
Renogy 50 amp DC-DC battery charger with MPPT
This allows you to charge the 200 amp hour auxiliary battery from the Jeeps alternator, OR from solar panels. Pretty cool. And because it pulls in 50 amps while driving, you can charge up the 200 amp hour battery in just a couple hours max. See below for more info on the battery.
https://www.renogy.com/dcc50s-12v-50a-dc-dc-on-board-battery-charger-with-mppt/
Renogy 12V 200Ah Lithium Iron Phosphate Battery w/ Bluetooth
It has a 1000 watt inverter hooked up to it (see below), so you can charge both AC/DC devices. This battery alone has lasted me 3+ days charging everything from Starlink, tea kettle, phone, flashlights, laptop and more. If the battery gets low, you can simply turn on the Jeep, let it idle and it will charge up the battery quickly WITHOUT taking up much gas at all.
The Jeep at idle will consume at max 1 gallon per hour. Most likely 0.5 gallon per hour (or less). So at 0.5 gallon/hour at idle, it would take 2 gallons of gas to charge up the Renogy battery from 0 to 100%. Which is pretty great. For peace of mind I always kept 5 extra gallons of fuel in a jerry can, that conveniently sits in the rear bumper mount.
https://www.renogy.com/open-box-12v-200ah-lithium-iron-phosphate-battery-w-bluetooth/
Renogy 1000W 12V Pure Sine Wave Inverter with Power Saving Mode (New Edition)
https://www.renogy.com/1000w-12v-pure-sine-wave-inverter-with-power-saving-mode-new-edition
Renogy 500A Battery Monitor With Shunt
https://www.renogy.com/500a-battery-monitor-with-shunt/
Renogy BT-2 Bluetooth Module
https://www.renogy.com/bt-2-bluetooth-module/
Renogy Communication Hub
https://www.renogy.com/communication-hub/
Go Rhino SRM500 roof rack
https://www.gorhino.com/series-458-srm500-universal-flat-platform-roof-rack.html#
Overland Vehicle Systems 270LT awning
https://overlandvehiclesystems.com/nomadic-270-lt-awning-driver-side-19559907-dark-gray-cover-with-black-cover-universal/
Ironman 4x4 powered water tank with pump (8 gallon) — comes with hose and shower head
Have the luxury of taking a shower during your overlanding/camping adventures. Or use to wash dishes, or your dog. Whatever you need, you’ve got high pressure water.
https://ironman4x4america.com/powered-water-tank-with-pump-8-gallon/
Kickass shower room awning with roof
https://kickassproducts.com/products/kickass-premium-shower-tent-awning-with-room
Smittybilt Overlander roof top tent (sleeps 2-3 adults)
Fishbone Offroad Interior Storage Rack
Raingler Overhead Ceiling Attic Net
Hothead Headliner. Front and rear side window panels. Helps with noise reduction and insulation. Had the back done as well, but needed to remove them when the roof rack got installed.
Tactic locking fuel door cover
I have the Carfax as of June 2024, and you will see in October 2023 a minor accident was reported. A stock Tacoma barely tapped into my front passenger tire just after making a turn, so we were both going maybe 5 miles an hour — there was absolutely no damage done to the Jeep or tire.
More pictures in comments below. Thanks!
nn0202
more pictures. please let me know of any questions. appreciate it!
sunnyaz
