2018 Mercedes Sprinter 2500 4x4 144” Campervan ($92,500)
MI147
This 2018 Mercedes Sprinter 2500 4x4 (144”) campervan has been very well maintained and has under 30,000 miles, many of which are highway miles. This is a custom floorplan which was built out by Sportsmobile North. The floorplan includes a driver side gaucho that opens to a bed and includes an extension for taller people (I’m 6’2” and found no need for the extension). Also in the floor plan is a wet bath that has a Thetford electric portable toilet. There is no onboard propane to deal with. Heat is provided by a diesel heater, and the dual stovetop is electric induction. This unit is well-insulated and winter capable. The floor plan has been maximized for storage. Below is a summary of the onboard systems and other features. This vehicle is located in Mt. Pleasant, Michigan. If you have questions, don’t hesitate to reach out.
ELECTRICAL
  • Equipped with factory second alternator on engine to feed house battery
  • Equipped with high idle control to use engine/second alternator when stationary to feed house battery if needed
  • AGM extended life battery
  • Magnum Energy MagnaSine 2000 watt pure sine waver invertor/charger
  • Magnum Energy Remote Control unit
  • True Induction MiniDuo dual burner induction cooktop (eliminates need for onboard propane)
  • NovaCool 3.5 square foot AC-DC refrigerator/freezer
FRESH WATER
  • 20-gallon fresh water tank under couch
  • Richmond 5-gallon electric water heater under sink
  • System can also be run off city water hook-up
WASTE WATER
  • Thetford Curve Porta Potti with electric pump
  • 10-gallon grey tank for sink
  • 10-gallon grey tank for shower
HEAT
  • Espar diesel heater (eliminates need for onboard propane)—very fuel efficient and gets the interior very warm, even in very cold conditions
AIR CONDITIONER
  • Dometic roof mounted 13,500 BTU AC unit
  • One Dometic Fan-Tastic roof vent fan is also installed.
ADDITIONAL UPGRADES
  • Goodyear Wrangler DuraTrac 245/75R16 tires
  • Custom screen for sliding door with dual zippers for easy in and out access
  • Also included is a DIY screen for the rear which simply consists of a large screen cut to size and magnets to hold it in place. There is no zipper built in, but this allows for sleeping with the rear doors open and does a perfect job of keeping bugs out.
  • Privacy curtain between cab and living area
  • WeatherTech floor mat across front floorboard
  • Portable table with tripod base and two height options
  • Seat covers were immediately installed when new so the seats are in perfect condition.
iStan814
