2018 Nissan NV 2500 high roof campervan conversion, 31K+ miles **REDUCED TO $53K**
laval
For sale is my full-time off-grid rig for two. Asking $60K OBO. Will deliver to the West Coast.
Highlights:
- Self converted (3 years) with love and attention to details
- 2018 High Roof Nissan NV 2500 V6 (original owner, Michigan registration, clean title) with 31K+ miles at the time of writing (Vancouver, Canada)
- A modular interior design approach is to use full 80/20 aluminum framing that it easy-to-change if you want to update/modify layout (CAT scale report shows that this build is in
compliance with Nissan's gross weight limit)
- Materials used for this build are as non-toxic and chemical free as possible: Baltic birch plywood for cabinets, solid oak for woodwork, ECO flooring, low VOC paint/sealant/adhesives,
natural cork for thermal/sound insulation
- Max temperature control without A/C (no mold allowed) by using reflective window covers, thermal curtains, good insulation, Maxxair and marine hatch on the roof, all
cabinets/panels have openings for good air flow and cork naturally resist mold
- Marine grade (Ancor) tinned wiring throughout, high quality electrical components (Victron, Blue Sea)
- No built-in propane system, AC, microwave
Van upgrades:
- Engine battery Group 27 X2Power model SLI27FAGMDP
- CRL FW801L Dual-Vent window
- Nissan sliding door glass (part #82300-1PC0A)
- Nissan cabin air filter 99MI-VP005
- Lewmar Low Profile Desk Hatch size 20
- Aluminum ladder at back door from Prime Design
- Aluminess front winch bumper with optional brush guard crossbar + 2 x CM 1" pin shackle and rear bumper
- Nitto Terra Grappler G2 LT245/75R17 on stock rims
- Added extra 1.5" leaf added to rear
- Added Sumosprings 1500lbs load capacity to rear
- Added Timbren suspension enhancement front kit to front
- Owl Vans Classic Large Cargo Box 30" with 2 gear plates
- Carefree 223000A 3m 9'10" manual awing
- Buena Vista add a room panels
- Aluminum lightweight headliner shelf for overhead storage
- Aluminum frame dog bed (never got one)
- Cabela's cot chair that slide on the side of dog bed
- Airvent cab window insert
- High-Strength 7075 Aluminum plates as an engine splash guard
- BUD Industries AU-1028 Aluminum Utility Box (used as entry points for cables where plastic ventilation box was located)
Appliances:
- Fridge Vitrifrigo VF62 39W 2.2Cu.ft. with Danfoss compressor 12/24V
- Engel MT27F-U1 top-Opening Refrigerator/Freezer 21L 17 Quart 110V/120V AC/12/24V DC
- Espar Airtronic B4 Gasoline Heater 4kW with EasyStart Pro Controller
- MaxxFan Deluxe Fan 6200K
- Sirocco II Fan, Omni-Directional Gimbal Fan 12V
- Furrion FIH1ZEA-BG Electric RV Induction Cooktop 1500W
- Thetford Porta Potti 565E Portable Toilet
Safety/Security:
- SeaDog MaxBlast SS Dual Horn #431520-1
- Blazecut automatic fire suppression system 3m TV300E
- Buckeye 13315 ABC multipurpose dry chemical handheld fire extinguisher 2.5 lbs
- Element E50 fire extinguisher
- Wireless alarm BT274 system with a receiver and 3 motion sensors
- Brandmotion Rear Camera (kit #9002-7608) with AHDS-7650 Universal 5" Digital Display Monitor
- Sensorcon Inspector CO Real Time Carbon Monoxide Monitor
Water:
- Gravity fed water supply from roof solar tank (hot water) for the summer and from jerry can for the winter
- TMC foot pump (model TMC-70701)
- 6-gallon water tank on roof (BAM MFG) + 3 x 20L water jerry can (two Scepter are plastic and one is stainless steel)
- 7-gallon under sink water tank
- Ambassador Marine SS sink
- RV style water fill-up
- Tuff Stuff outdoor shower tent
Lights:
- 240W LED 50" curved light bar from Rough Country #72750BL
- Diode Dynamics Stage Series 3" SAE/DOT Type FT Fog Light Kit
- 2x18W Heise 6 LED Cube model HE-CL3S2PK
- Heavy Duty Dual Output Light Bar Wiring Harness Diode Dynamics
- Dream Lighting 12V 3.5" LED Luxury Crystal Panel Light 3pcs
- Lunasea Adjustable Linear 12” LED Light w/Built-In Dimmer 12VDC
- MASO 12V Spot Reading Light Interior Lighting Wall Lamp with Switch
- Magnetic Solar Motion Light
Electrical:
- Renogy Eclipse Solar Panels x 4 total 400W
- Lithium Battle Born batteries x 3 total 300Ah
- Victron Energy SmartSolar MPPT 100/50
- Victron Energy MultiPlus 12/2000/80-50 120V (UL 458) Inverter Charger
- Victron Energy BMV-712 Battery Monitor with Bluetooth Built-in
- Victron Energy Color Control GX
- Victron Energy Digital Multi Control 200/200A
- Victron Energy Temperature sensor for BMV-702/712
- Victron Energy Orion-Tr IP43 12/12-Volt 18A 220W Isolated DC-DC Converter
- Victron Energy Battery Alarm GX
- Victron Energy CCGX Wi-Fi Module Simple (Nano USB)
- Victron Energy VE.Bus Smart Dongle (Bluetooth)
- Victron Energy Wall Mounted Enclosure Panels
- USB GPS Navigation Receiver BU-353
- Blue Sea temperature monitor ‎1741
- Blue Sea 1733-BSS Mini Digital DA Voltmeter
- Blue Sea 6010200 M-Series Battery Switch Dual Circuit
- Blue Sea Weather Deck Waterproof Panels 4 pos fused
- Blue Sea 5025 ST Blade Fuse Block 6 Circuit
- Blue Sea 5045 ST Blade Fuse Block Compact 4 Circuit with Cover
- Blue Sea A-Series Toggle Single Pole Circuit Breakers
- Blue Sea 2723 Dual Bus 150A Common 4 x 5/16" Stud and 5 x 10-32 Screw Terminal
- Blue Sea 5191 Fuse Block Terminal 30-300A
- Blue Sea 5117 225A Class T Fuse
- Sterling DC Battery to Battery Charger 24V-12V 35A
- Sterling White Remote BBURC
- Bosch 0332019157 Normal Open Relays - 4 Pins, 12V, 40A 3pcs
- All power cables are from Battery Cables USA
- Wago Compact Wire Connectors
- Bussmann BP/ATM-2 Fast Acting Mini-Fuses
- Bussmann HHL In-Line ATM Fuse Holder - 32V/20A
- 15 Amp Shore Power hookup
- 3 x 110V outlets
- 3 x 12v Dual USB chargers
Included:
- Starlink V2 mobile internet
- Coleman 533 Sportster Fuel Stove
- Dashcam AdvoCam-FD2 Mini
- RAM X-Grip Phone Holder with Ball Mount
- LogicBlue Technology LevelMatePRO Wireless RV Level Monitoring
- Timegyro LED Alarm Clock CRS1
- Ambient Weather WS-10 Wireless Indoor/Outdoor Thermo-Hygrometer with 4 Remote Display
- 2-way Radio GMR5089-2CKHS (set of 2)
- RotopaX fuel tank for Espar heater
- Snow Peak lamp ES-070
- Snow Peak IGT 4 unit sitting set - Iron Grill Table
- Snow Peak IGT Rack
- Spare Nissan mud front flaps
- Seat cover (2 ps)
- Leather steering wheel cover
- VanEssential window covers
- Custom made Bugs Wall mosquito net with magnetic entrance and rear bug screen
- Emergency Toilet (Snow Peak Jumbo Camping Bucket)
- Marinco 15A Marine Grade Locking Extension Cord
- AIDA 2' Auto Reset 12/3 Gauge SJTW GFCI Extension Cord, 15A
- NOCO GCP1E 15A AC Port Plug 6' Extension Cord
laval
Extra pics
laval
The price has been lowered a second time after a previous reduction to $53K obo
Note from the owner:
To justify the asking price here is my explanation what are you getting for it and why it's worth it:
- This turnkey campervan build means that you'll get tried and tested fit-out, materials, and expertise without the stress of DIY or the decision-
fatigue and cost (I will provide a full van tour with step-by-step explanations of how to operate/routine maintenance on van's systems)
- Reliable Nissan NV2500 V6 RWD with low mileage (31K+ miles) at the time of writing
- Marine grade tinned wiring throughout, high quality electrical components from Victron and Blue Sea companies
- Materials used for this build are as non-toxic and chemical free as possible: Baltic birch plywood for cabinets, solid oak for woodwork, bamboo eco
flooring, low VOC paint/sealant/adhesives, natural cork for thermal/sound insulation
laval
Here are some pics to show current layout. Passenger's seat is back, and the second sleeping place had been added.
sunnyaz
