2018 Tacoma Pro, 6 Speed Manual!!!
Coarsegold1
2018 Pro 6 Speed Manual. No corners cut, no excuses fine tune. 258 hours of labor later, it is done!
Full image file: https://drive.google.com/open?id=1U2jKHZnwyqkWvq78eT9dl0Do27WaxFAR
If you are a Tacoma aficionado, you already know this truck is a unicorn. It was a special order from TMS that took months to get. As much as I love the Pro, there were a number of areas that needed to be addressed to dial it in. This was a no corners cut, no excuses fine tune. 258 hours of labor later, it is done!
Please copy/paste this URL for the full image file: https://drive.google.com/open?id=1U2jKHZnwyqkWvq78eT9dl0Do27WaxFAR
Audio / Visual (sounds like a recording studio inside):
  • JL Audio 10TW3-D4: 10-inch Subwoofer Driver, Dual 4 Ω
  • Mr. Marv's Custom Subwoofer Enclosure (Full system tune by Mr. Marv)
  • Mr. Marv re-pinned Tacoma wiring harnesses & 9 conductor Speedwire
  • Arc Audio XDi850.5 Amplifier
  • Audiofrog GS610C Premium Grade Passive Crossover Network
  • Audiofrog GS62 6″ Premium Full Range Loudspeaker with 1” fabric dome neodymium tweeter (pair)
  • Audiofrog GS60 6″ Premium Midrange Loudspeaker (pair)
  • Audiofrog GS10 1″ Premium Tweeter Neodymium motor with copper pole piece cap (pair)
  • Custom Adapters for Audiofrog Speakers
  • Noico 80 mil Sound deadening mat
  • Hondo Garage Premium Stereo Knobs
  • Audiovox ACA801 Front Camera
  • Front, Rear Camera, Navigation Bypass, Smartphone Mirroring Mod. (all on microswitches)
Lighting (clean, clear, bright white light in front, in back, and inside):
  • Phillips HID Conversion Kit (Low Beams) with spare Phillips bulbs
  • HIKARI LED Headlight Bulbs Conversion Kit (High Beams) - Bulbs were Indexed
  • Sylvania 58896 - 35BT4Q_IR_OSRAM Reverse Lights
  • mesojdm (Tacoma World) Custom LED V1 Smoked Map Light and Ultimate White Dome light
  • MicTuning Flush Mount Led Pods (Rear Bumper Lights)
Custom Electric & System Upgrades (100% copper wiring & terminals, tinned connectors, fluxed/soldered, sealed with marine double wall glue impregnated heat shrink, dielectric grease, nuts/screws with Loctite 242. Techflex F6 split sleeve (1/4, 3/8, 1/2, 3/4, and 1") - edges Tesa taped & Cable Ties every 6 - 8". Front and rear systems are set up with excess capacity to be easily expandable to meet future needs):
  • Northstar NSB-AGM 27F Group 27F Battery
  • Knukonceptz Battery Terminals
  • Battery Tray 74431-0C020
  • #1 Gauge AWG - Flex-A-Prene - Welding/Battery Cable - Black & Red (20' of each to remote winch front/rear)
  • Selterm 1/0 Ga. 1/4" Stud UL Marine Heavy-Duty Lugs Battery Cable Tinned Copper Eyelets
  • Littelfuse HWB18 Waterproof Sealed Fuse Relay Panel Block Kit
  • Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover
  • Blue Sea Systems 285-Series Circuit Breaker (Two)
  • TE Tyco 75 Amp High Current 12 Volt Automotive Relay SPST
  • 4 Guage Cable & Terminal Ends
  • 6325G1 Anderson Original Battery Connector 175 Gray With 1/0 Tips
  • Quick Connector Dust Cover Cap for 175AMP Plug (Front / Rear)
  • 2016-2018 Toyota Tacoma OEM Style Switch Panel
  • (2) Toyota 55539-AE010-C0 Switch Hole Cover
  • (2) Rocker Switch Panel Plug #ACPP
  • Iztoss Toyota Blue LED Push Switch with Connector Wire Kit (Rear Lights)
  • 2 Techflex 3/4 F6 Split Sleeve (25 feet Black)
  • Ancor Marine Grade Primary Wire and Battery Cable (Red, 100 Feet, 18 AWG)
  • Ancor Marine Grade Primary Wire and Battery Cable (Red, 100 Feet, 12 AWG)
  • (2) Low Profile Mini Fuse Tap
  • (2) Thermo-Tec 13500 12" X 12" Adhesive Backed Heat Barrier
  • Tesla Dual USB Charger Socket, Waterproof Marine USB Power Outlet with Voltmeter LED Digital Display
Bed (functions like a truck bed or like the trunk of a car):
  • BAK BAKFlip Revolver X2 Tonneau Cover (#39426)
  • OEM Toyota Tacoma Bed Mat
  • (4) OEM “D” Rings
  • Matt Gecko LED Bed Lighting System
  • AMP Research 74811-01A BedXTender HD MAX, Black
  • AMP Research 74605-01A BedXTender Mounting Kit with Quick Latch
  • Truck Upfitters Premium Pickup Truck Bed Tailgate Seal
  • ROK BLOCK Tailgate Gap Cover 4.25" width
  • Pop & Lock PL8535 Power Tailgate Lock
  • Tacoma "Bed Cubby Caps"
Additional Details:
  • Mobtown Offroad Front Receiver Hitch
  • Powder Coating Mobtown Receiver Hitch (60% Black)
  • OEM Toyota PT228-35960-HP Receiver Tube Hitch Plug (front hitch)
  • Draw Tite 5330 Black Rubber 2" Square Receiver Hitch Tube Cover (rear hitch)
  • Jowett Billet Oil Cap w/ Drain Valve
  • Fumoto Oil Drain Valve / Saftey lock / Cap
  • Toyota Tacoma Center Console Tray
  • (2) Hyq12Bdp 2018 Toyota Tacoma H Chip Remote Flip Keys (Plus both factory keys)
  • Air Conditioning Drain Mod
  • KA Smoked Stainless License Plate Frame with stainless button head bolts
  • Ceramic 35% Window Tint
  • WeatherTech Floor Liner System, First and Second Row (# 4413011-448722)
  • Custom TRD Pro Decals for Weathertech Floor mats
Notes:
  • Debaged (all are in perfect shape and are included)
  • No smoking, no accidents
  • Setup for portable/quick disconnect winch front/rear (winch not included, but available separately)
  • Most recent software update (8966304A7100)
  • Serviced at 1315, 5041, and 9948 miles (All with Mobile 1 Full Synthetic and OEM filters)
For Sale:
Unfortunately, I have a seemingly incurable “car” disease. My love however is in the dreaming, hunting, and building stages. Once they are done, well… they are done. As such, I have already bought my next “project,” so the Pro is now a detailed garage queen. Although it may vary slightly, it currently has just shy of 12,750 miles on it. I have the clean & clear title is in hand. With all due respect, please understand that I don’t “need” to sell this, and as such, my price is very firm. You can do the math on the build, and you won’t get very far down the list when you realize this truck couldn’t be replicated at anywhere near the $49,999 price; and that is IF you can find a manual Pro! Located in Clovis, CA 93619.
4xCoffee
