courtney1234
FOR SALE: 2018 Toyota Tacoma with AT Overland Atlas Camper
Canadian Plates (Alberta)
Price (US Dollars): $75,000
This truck is loaded and built to go anywhere. It was recently driven from Canada to Nicaragua and back to Mexico. It is extremely well taken care of and in excellent condition.
Build Specs:
2018 Toyota Tacoma TRD Sport, Double Cab, 4WD, Long bed, Technology Package
Kilometres: 105,000
Suspension:
Truck Accessories:
AT Overland Atlas & Camper Accessories (All installed in 2021)
Camper Interior:
Solar Battery System:
Build Specs:
Kilometres: 105,000
Suspension:
- Elka 2.5 Reservoir Shock Absorbers Adjustable Rear Reservoirs and Non-Adjustable Fronts with Eibach 700lb Coils
- SPC Upper Control Arms
- Dobinsons Super Heavy Duty Leaf Pack 1200-1500lbs
- Wheels: Stealth Custom Series F5 Matte Black 17”x9” -38mm Offset
- Tires: Yokohama Geolander G003 MT 35/70/17 (70% Tread Remaining)
- Spare Wheel and Tire Included
- Wilco Off-Road Hitch Swing Spare Tire Carrier with Front Runner Drop Down Table
Truck Accessories:
- Total Chaos Spindle Gussets and Cam Tabs
- RA Motor Sports Aluminum Engine Skid Plate
- C4 Hybrid Mid-Loop Front Bumper & C4 Support Brackets
- Smittybilt X20 Winch 10000 lb with Upgraded Synthetic Winch Line
- Factor 55 Flat Link & 1.5” Fairlead
- Nitro Gears: 4:88
- OV Tuning Kit For 35” Tires and 4.88 Gearing
- Eaton Detroit Rear Locker
- Magnaflow Exhaust
- S&B Cold Air Intake
- Diode Dynamics Pod Lights
- Custom Welded Rear Shackle Cross Bar
- CoverKings Neoprene Seat Covers
- Brand New (Uninstalled) Spark Plugs. Engine Coils, & Elka Spherical Bearings
- AT Overland Atlas Camper
- Front Cab Slider Window
- DS 450x1100 Slider Window with Fixed Bug Screen
- Rear Liftgate Window
- 12v Power: 1x12v Port, 1x Double USB Port, 2x ¾” LED Lights (White)
- Pre-Wire for Solar with 10GA Wire
- MaxxAir 6200K Fan
- AT Awning Brackets
- Overland Vehicle Systems 270 Nomadic Awning
Camper Interior:
- Custom Built Cabinetry
- ARB Fridge on 600lb Slide
- LED Strip Lights
- Custom Made Memory Foam Cushions
- 2x Renogy 100 Watt 12 Volt Flexible Monocrystalline Solar Panels
- 3x Renogy Lithium Iron Phosphate Battery 12 Volt 50 Ah
- Renogy 1000W 12V Pure Sine Wave Inverter
- Renogy 12V 40A DC to DC On-Board Battery Charger
- Renogy Rover Li 20 Amp MPPT Solar Charge Controller
- Renogy 500A Battery Monitor With Shunt
