Page 1 of 4 123 ... LastLast
Thread: discovery I engine swap
  1. #1
    Default discovery I engine swap
    newbie on the forum owns a '95 disco I. was wondering if anyone knows of any small block v6/v8 swap for this truck? something with more torque
  2. #2
    Join Date
    Sep 2007
    Location
    Longmont CO
    Posts
    682
    How much $$$ do you have?
    I could tell you about tons of options, most of which don't make sense...
    Cheers!
    Keith
    04 Dodge 3500 4X4 CUMMINS POWERED!
    RT1 '97 Disco SD (on steroids) Sold
    RT2 '97 Disco XD (built to rock)
    RT110 '85 110 (Getting bigger, badder and better)
    '95 RRC LWB (Sadly it is sold )
    '67 S2a 109 SW (someday I'll finish it) Sold...
  3. #3
    Join Date
    Nov 2005
    Location
    Anchorage, AK
    Posts
    1,623
    Default 4.3L swap
    http://expeditionportal.com/forum/sh...highlight=4.3L
    It likely won't be cheaper than a Rover engine, but it is an option.
    There's also the 2.5L diesel if emissions aren't an issue for you.
  4. #4
    Join Date
    Sep 2007
    Location
    Longmont CO
    Posts
    682
    Quote Originally Posted by Alaska Mike
    [There's also the 2.5L diesel if emissions aren't an issue for you.
    Which one? 200, 300, TD5, 2.5 NA (gag)
    These all cost $10K plus unless you have skilzzzz.
    4.3 GM? Better to work over the old buick (=Cheaper)
    Any other V8? The engineering will cost more than the truck is worth.
    Put in some gears to handle those big tires? Now that makes sense..
    Cheers!
    Keith
  5. #5
    Join Date
    Nov 2005
    Location
    Anchorage, AK
    Posts
    1,623
    That's the sad truth. I like the 4.3L as an engine, but the amount of adaptation is considerable.With as many cheap Discos there are out there, you can probably find donor rigs for much less than a swap would cost, with a lot less hassle. Even rebuilding that mill would probably take it well past the chassis' conceivable lifespan. Does anyone really believe we're going to be using rigs that get 15MPH (at best) in 15 years time? Based on fuel prices and the drive to more efficient travel, I'm waiting for my algae-based, bio-fuel jet pack.
  6. #6
    Join Date
    Nov 2007
    Location
    Upstate NY
    Posts
    349
    http://www.rangerovers.net/rrupgrades/index.htm#swapgm
    http://www.mez.co.uk/chevyupgrade.html
    I have a friend who swapped in a TBI 305 into a D1 but he ended up essentially gutting the thing and used TH350 and NP205...
    Now he is looking into a 383 for it but the time and $ he has put into the swap- it is a lot- even with junkyard parts. He intends to keep the D1 forever so the $ involved really were not an issue for him.
    1944 Willys MB
    1965 SIIa 88"
    1970 SIIa 88" RIP
    1971 FJ-40
    1973 SIII 88" RIP
    1975 Ex MOD 109" Ambulance/GS project
    1989 Range Rover (Xs 2)
    Blah, blah, blah...
    Originally Posted by R_Lefebvre
    Being stranded with near zero warning is just not cool, especially if you're going off-pavement.
  7. #7
    Toyota 2F....... yeah baby. Practically a tractor motor. Inline 6 cylinder
    2004 UZJ100 Land Cruiser
    "The Warpig"
    My build-
    http://expeditionportal.com/forum/sh...ad.php?t=14449
  8. #8
    Join Date
    Mar 2008
    Posts
    5,543
    GM just announced they will be selling crate LS9's...
  9. #9
    Join Date
    Mar 2008
    Location
    Ottawa ON
    Posts
    164
    Quote Originally Posted by LC/LR4Life
    Boat anchor, 10 mpg.
    Oilburner
    Ottawa, Canada
    Quote Originally Posted by Yorker View Post
    Land Rover made a business out of more or less making trucks from car components, that doesn't mean you have to do the same.
    1980 Land-Rover crew cab project, 6BT, NV4500...
    1994 FZJ80 powered by a Mitsubishi 4D3 TDI:
    http://forum.ih8mud.com/diesel-tech-...-94-fzj80.html
  10. #10
    Join Date
    Sep 2007
    Location
    Longmont CO
    Posts
    682
    Quote Originally Posted by Oilburner
    Are you suggesting a 6BT can fit?
    Cheers!
    Keith
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
