2019 F450 single cab, singles, rack
wehring
2019 F450, single cab, 6.7 diesel, 4.30 axle gears, factory bed liner, 360 deg cameras, elec mirrors, 4x4 shifter on the floor
30,000 miles - still under factory warranty
converted to super singles with custom Hutchinson 20x9 wheels, overland rack loaded with rigid lights, McNeil fenders, ceramic window tint, CR Lawrence rear sliding window, 37x12.50r20 Nitto Ridge Grapplers, Fabtech leveling kit, 2” rear blocks
$92,000
Near Houston, TX
979 997 3one12
AbleGuy
Officious Intermeddler
Beautiful truck!
Hey guys, here’s one that you can actually load up with all the weight of all of your gear and also put a big azz camper on, and not worry one bit about being over your GVWR!
adam88
I read through your build thread. This thing is awesome. I was wondering about more info on the McNeill fenders? Are they 3" or 6"? Does the fender fully cover the front tire? Out where I live it is illegal to have the tire tread stick out past the fender.
wehring
They fully cover the tires. +6” McNeil fenders. They are cheap to buy but expensive to install. I have $6k in the fenders but the purchase price was $700. They had to add glass to areas that were mostly bondo, cut the mounting tabs off to relocate, sand the ripples out of the surface, and paint. I am very happy with the final product but a quality install will make or break the outcome. My opinion is that wide fenders complete the super single conversion on the F450/550 trucks and give it a Raptor look. Without them the front tires stick out much too far.
I assume that McNeil focuses on desert runners that consider these disposable.
wehring
There is also a large gap between the factory fender liner and the McNeil fenders. We closed this gap with an aluminum plate we made and riveted in place. Without this plate the engine compartment will be filled with dirt/mud
DanoWall
