2019 ITWO Boreas XT Overland Camper - Price Reduced!
thoman04
$27,500 obo
Off-grid, Off-road Adventure Trailer
Single-owner
Garage-kept
~3,200 miles – like new!
Local pick-up only, Denver metro area
Specs
Overall length- tongue to tail – 15’6”
Overall width – fender to fender – 7’
Overall height (w/ awning) – 6’4”
Dry weight – 1,950 lbs
Tongue weight – 230 lbs
Rated weight – 3,500 lbs
Water / propane / cargo capacity – 1,550 lbs
Trainer Chassis
3” x 2” x 1/8” CNC cut steel frame – powder coated
Timbren axle-less independent suspension – 3500lb HD
30” x 9.5” BF Goodrich All Terrain TA Ko2 tires
15” steel Pro Comp wheels – 6 x 5.5 bolt pattern
7-pin electrical harness
LED trailer lights with reverse
Electric Trailer Brakes
Tekonsha Bluetooth Brake Controller
Lock N Roll articulating hitch coupler
Tongue jack with rubber wheel
Deep Cycle Battery ******
Oversized aluminum tongue box ********
20-gallon water tank with skid plate
Jeep style fenders with matching diamond plate steps
Rear stabilizers
Full sized spare
Rear 2” receiver hitch (325lb max)
Exterior
Aluminum-studded composite cabin – no wood anywhere!
Driver and passenger side entry doors with screened windows
11lb propane tank with mount
100 watt solar panel
Solar charge controller with LCD display
Instant hot water shower *********
Custom aluminum roof rack with 4 large cross bars (500+lb max)
ROAM Adventure 8’ awning (brand new 12/22)
Trasharoo tire bag
Wheel lock*********
Cabin
Oversized composite cabinetry
Composite maple wall paneling
Fully insulated walls, floor, and roof
Propex forced air furnace (6500btu)
Interior 12v/USB-A/battery gauge power panel – 110v plugins
Intelli Power Center with shore power 12v/110
Integrated battery tender
Maxx Air Fan with 4 speeds (all-weather operation)
4.5” custom memory foam queen mattress (6’7” head-to-toe)
Rubber diamond plate floor
2 LED side porch lights
LED Interior lighting with dimmer
LP/Co2 & smoke detector
Galley Kitchen
Pullout stainless steel sink
Self-priming water pump
Pullout stainless steel Dometic 2 burner stove********
Pullout 12v/120 Dometic CFX 40 refrigerator
Composite cabinetry with interior shelving
LED lighting with dimmer
Overhead LED porch light with dimmer
Kitchen 12v/USB/battery gauge power panel – 110v plugins
Stainless steel countertop
Paper towel holder
