2019 Tacoma TRD OR MT 3xxx miles Alucab Canopy Camper -- Ready for Adventure!
ZioEdo
Hello All,
I selling my 2019 Tacoma DCSB TRD OFF Road, 6 Speed Manual, overlander build with 3xxx miles. I purchased the truck new and started the build in January of 2020. The truck has been stored inside since I it was purchased. Title is clean and in hand. My situation has changed and I am offering it for sale. I have spent over 75K not including tax, shipping and labor to install. I am sure I have not accounted for everything that I put into it. I figure that given the current market conditions and the fact the truck and mods are essentially new that now is the time to try to sell. If I can get my price I will sell it, if not I will keep it.
I put a lot of thought and energy into this build. I have documented most everything of what I have done with detailed photos, all of which will be passed on to the new owner. I have all of the receipts and original documentation that came with the components.
I am not going to be parting the truck.
I initially was going install a second battery in the bed and mount solar on the roof. Instead I purchased Jackey 1000w power station and 2 160 Watt panels. I ran #2 AWG welding cable from the main battery to the camper unit. So if someone wants to have an aux battery in the camper they can as the conductors are sized to accommodate this. Currently I have the option to power the camper from the truck battery or I can input the jackery into the camper directly and power it from that. You will notice in the photos there is a main disconnect, selector switch (truck or aux input), 10A thermal fuse and aux input. This set up works nicely as now I can park in the shade and put my panels in the sun. Also while moving I can charge the Jackery from the truck’s inverter. I am keeping the Jackery and panels and the dometic cooler I use.
Known issues. I cracked the plastic cover over the in center engine bay with, barely noticeable. Could not get the Sirius XM to reliably with external antenna. Navigation works fine.
Unfinished items which i will be completing. I need to seal around the door and back panels with Sika Flex.
Personal items are not included. Maxtrax not included. I temporally strapped the Maxtraxs. I wanted to show that the gas shocks could support lifting and holding them in place.
I still have the entire back passenger compartment including hardware should someone want to return it stock.
Truck is located 30 minutes from Albany NY
Thanks for looking.
Stock Truck Details
2019 Toyota TRD OR DCSB, 6 Speed Manual, Rear Locker, 4.30 gearing, Leather,Sunroof, Dual Climate Control, navigation. 3,xxx miles
Build Details
Rear Molle boards
Shadow Awning
Gutter
Slide out table and tray
Netting on sides and rear door. Rear door not installed
Alucab Load Bars
Rear door tire carrier, not installed
Wired for solar with Anderson connector on roof
Suspension
ARB Old Man Emu 2” Lift with 600lb. heavy duty leaf springs, ARBOMETAC16BP51B
SPC Upper Control Arms
Armor
ARB Summit Front Bull Bar Bumper
ARB Summit Front & Side Rail Protection
ARB Summit Rear Bumper
ARB Under Vehicle Protection
Performance
SOS Performance Front Brake 6 PISTON FRONT BIG BRAKE KIT TR325.6TA
ARB Front Airlocker ARBRD111 30SPL 3.91&UP
ARB Compressor CKMA12
Lighting
Baja Designs Squadron Pro - BAJ497803 – Ditch Lights
Baja Designs S2 Pro Flush mount --Backup lights
Baja Designs S2 Sport Red Lens – Exterior Camper Light
Baja Designs S2 Sport Clear Lens – Exterior Camper Light
Baja Designs LP9 driving combo LED lights BAJ320003
Electrical
Odyssey Battery ODY31M-PC2150ST
Camper Integration
Truck Battery Isolation- Blue Sea 30A Breaker Disconnect
Selectable power source- Truck or Auxiliary Input
Auxiliary Input – Blue Sea 12V Female Receptacle
10 amp Resettable Thermal Fuse
Blue Sea Waterproof Circuit Breaker Switch Panel
Blue Sea USB Charge ports (2)
Blue Sea 12V Charge Port
Blue Sea Mini OLED Exterior Temperature Monitor
(2) #2 AWG Carol Welding cable ran from truck battery to camper
(8) extra 12AWG conductors ran from engine bay to camper
Baltic Birch Plywood Floor with Threaded Inserts, Marine Varnish w/non skid
Baltic Birch Plywood Camper Inserts, Marine Varnish
Bantam SPOD with HD Panel, Blue Tooth, one position open
Recovery
Warn Zeon 10S Winch, 10K lb, Synthetic Rope
ARB Recover Point, 8 Ton Capacity
Hi Lift Jack and Mounts
Factor 55 Ultra Hook and Rope Guard
Factor 55 Hawse Fairlead
Interior
Goose Gear 60/40 Seat delete
Expedition Essentials 3TPAM Accessory Mount
Weathertech Front Floor Mats
Tires
(5) BF Goodrich LT265/75R16123/120RAT/TAKO2LRE
Spare Mounted on Steel Wheel, Stowed under bed.
Miscellaneous
SLEE Compressor Mount
Power Tray – SPOD Mount
Cali Raised Low Profile Ditch Lights Mounts
Expedition Essentials Propane Bottle Mount – Not installed not photographed
Price: $75,000 OBO
ZioEdo
More Photos
ZioEdo
And More
ZioEdo
I have many more photos to share.
ZioEdo
Is this still available?
Thanks,
Becky
Hi Becky,
Yes it is. In fact i have done more work adding a 13 gallon water tank, chest of drawers and 12V water pump (still needs to be installed). Here are some photos. I will be installing L track on top of deck so gear can be tied down securely. The price needs to be adjusted to reflect extra items.
ZioEdo
Hi Becky,
Thank you. It has been a labor of love!
It currently has two seats. However i still have the all the rear seats, seat belts and hardware to turn it back to original if someone wanted to.
Take care,
Ed
secono
Still available? Looking for an Alu Cab if it is and you're willing to separate at this point. Thanks. @ZioEdo
