2020 4x4 Mercedes Sprinter Van -$95,000
glenmorden
Located in Santa Barbara, CA
Asking price $95,000
**Van Interior has been re-powder coated and restored to "new" condition.
Vehicle Specifications
(98,000 miles)
  • Engine: 3.0L V6 Turbo Diesel
  • Transmission: 7-Speed
  • Roof: High roof
  • Drive: 4x4 High Range T-case with Low Gear
  • Comfort Package
  • Sliding Side Cargo Door: Two-stage with soft closure
  • Keyless Start: 4 key fobs
  • Windows: Tinted rear and side windows
  • Heated Front Window
  • Rear Window: Defroster and wipers
  • Seats: Swivel leatherette captain seats, programmable seat positions, bench seat 2 with seat belts
  • Cruise Control
  • Safety Features: Multiple safety features
  • Wheels and Tires: BFG All Terrain T/A KO2 tires with Jetblack rims * (also have stock take offs that are brand new)
Exterior
  • Rear Trailer Hitch
  • Thule Awning: 10’
  • Aluminess Side Ladder
  • Flatline Van Co Low Roofrack
  • Connections: Shore power and water
Interior - Custom Build by Rigracks.com in CA (https://www.rigracks.com/orion)
  • Insulation: Roof, walls, and doors properly insulated for sub-zero conditions. Thinsulate on large areas such as walls and sliding door. Reflectix and foil tape used as a vapor barrier. Butyl sound deadening applied.
  • Overhead Storage Compartment: Dual flip-up doors, fabric walls, black laminate doors, Southco latches, interior light.
  • Vent/Fan: Maxxair 6200K
  • T-Vent Window: CRL T-Vents windows
  • Ceiling Paneling: Unfinished cedar, 8 recessed puck LEDs, cut-outs for vent and door-stay with cover.
  • Wall Paneling: Interior wall bracing and bed supports, panel with 1/4 ply laminated with foam and fabric. Decorative black fasteners. Cut-outs for window, L-tracks, outlets, remote controls, plumbing, and wiring. Built rear door frame to match walls with inset USB ports, switches, and to conceal factory wires and plumbing.
  • Bench Seat Table and Shelf: Low-profile wall-mounted flip-up table with shelf for bench seat.
  • L-track Installations: 9 track installations: (4) wall, (1) floor with arrow heads and cover, (2) seat tracks with cover, (2) bed rails.
Solar Panels
  • Panels: 3 - 100 watt Renogy Eclipse Monocrystalline Solar Panel High Efficiency Module
Bed System
  • Custom designed support rails to integrate with L-track installations. 3 panel platform setup with premium inset panels: black laminate on bottom, fabric on top.
Bed-side Cabinet Unit
  • Dimensions: 8"x 8" bed-side storage unit on passenger-side with 3 stay-open flip-up doors. Electrical control panel on front.
Surfboard Storage System
  • Surfboard Strap System: 1.5"x.75" tubing on front and back edges. 60" LED light-strip installed below.
Floor
  • Material: Grey small coin polyvinyl floor. Insulated with 1/2" poly-iso foam below sub-floor. Fully sealed sub-floor perimeter.
  • Storage Drawer: 22" slider-step storage drawer. Recessed black powder-coated aluminum trim. Powder-coat seat brackets.
Driver Side - Garage Unit
  • Storage: Flip-lid storage cabinet in the rear and a discrete lock-box in the front. Unit encases the insulated wheel well and all electrical components, 2 batteries, and fuse panels. Inset panels are laminated in coin flooring with black laminate inside all cabinetry.
Passenger Side - Garage Unit
  • Water Tank: Unit to encase NWS 22L water tank, pump, and plumbing; designed to include shower storage cabinet and shower connections on both front and rear. Water tank insulated with poly-iso foam and LED level-inspection light installed.
sunnyaz
