After less than 2 years and 21k miles the front passenger Fox 2.5” DCS shocks was seeping a bit of oil. We were planning to revalve all four shocks and decided to rebuild them at the same time. The shocks were purchased through AccutuneOffroad.com. They provide custom shock valving for your application. Plus, they will revalve the shocks FREE (one time) if the shocks need further tuning.
In our case, the shocks worked perfectly while loaded with the adjusters turned up 2 clicks. However, the ride was a bit firm when unloaded and the adjusters turned to zero. I wanted to slightly reduce the valving to allow a more compliant ride unloaded with the same performance while loaded with the adjusters turned up.
Here’s the rebuild process:
1 – Remove Shocks (2 hrs)
2 – Box & Ship Shocks to AccuTune
3 – Wait... (estimated 4 weeks – our turn around was 1 week)
4 – Install Shocks (2hrs)
All Performance Shocks (including King, Icon, Radflo) are rebuildable which is great considering they cost $650+ per shock. However, our basic rebuild cost was $160/shock (including shipping) plus we had to wait for them to be rebuilt.
I’ve considered buying a second set of FOX shocks to avoid “down time” waiting for the rebuild. But that is an expensive option! Instead I purchased a cheap set of ProComp shocks (proper length) that could be used during the rebuild. You can’t beat the performance FOX shocks offer but they are spendy!
Here’s the FOX ATS Steering Stabilizer mount drop info:
The Part# for the stabilizer hasn’t changed — We made a change to the hardware kit to include the reducer/spacer and longer bolt. If a customer is ordering a new stabilizer its already included and if a customer already has the stabilizer and needs the hardware we have been supplying no charge. I’ve listed the spacer, bolt and washer #’s below if you need it.
Reducer – 213-01-586
Washer - 018-05-065
Bolt – 018-04-057
