2021 Alu-Cab Khaya 2-Sleeper
Summit4x4ORAS
Brand New Condition / Never Used / Must See to Appreciate.
Approximately 9 month delivery time if purchased directly from Alu-Cab.
Fits trucks with a 5.5' Bed or bigger. Designed for mid-sized trucks (Tacoma, Ranger, Colorado, Frontier, Etc.)
FEATURES:
* Shadow Awning Side Wall Kit
* Reico Titan Jacks and Brackets
* Sunflare 126W Solar Panel Kit (2)
* Jerry Can Holder
* 11lb. Propane Exterior Tank Mount
* Load Bars (2)
* Load Bar Feet (4)
* Shower Cube
* 2 Burner Stove
* Sink (Dometic Brand)
* Hot Water Heater (Dometic)
* Diesel Furnace
* Group 31 AGM Battery
* Indoor and outdoor lighting
* Multiple USB and 12V Outlets
* Lots of Storage and MORE!
Main bed section: 1925mm x 1225mm
Rear bed section: 1225mm x 580mm x 1340mm
Length (overall): 2859mm
Height (overall roof closed): 1483mm
Width (overall): 1850mm
Height (overall, roof opened – from base to highest point ): 2800mm
Dry weight / Fully kitted weight: Approx 880lbs. empty basic, 1697lbs.
ROOF PACKING LOAD
Be mindful of the Khaya Roof packing load of 110lbs. It is important to note that where the load is located on the Khaya roof, will determine how easy or difficult it is to open. It is always suggested to shift heavier loads towards the front of the tent, and much lighter loads, like a solar panel, to the rear.
*Truck NOT Included*
PRICE:
$29,599
For more info, please contact Ashley at 928-442-7222 or visit www.summit4x4offroadautosales.com
IMG_0292.jpgIMG_0274_2.jpgIMG_0287.jpgIMG_0292.jpgSummit4x4Co-IMG_0328.jpgSummit4x4Co-IMG_0334.jpgSummit4x4Co-IMG_0352.jpgAC1.jpegAC3.jpeg
Summit4x4ORAS
Hello Havagr81!
My name is Ashley. Yes this Alucab is still for sale! As far as fitment on your Ram, AluCab does not make a specific bracket kit for the Khaya camper to be installed on the full size trucks. This particular camper from AluCab can be installed on Rangers, Tacomas, and potentially Frontiers, Colorados or Canyons.
Hello... still for sale? If so will it fit my 2021 ram 1500 5.5 bed warlock? Hemingway 4 x 4?
Can I finance through you?
Clemtiger84
