gonuclearnavy
2022 AS-1 LIMITED with Upgrades
*NOTE: as silly as this sounds, I thought it was a 2021 model, and didn't realize my mistake until I pulled out the title to make sure it was handy. I've updated the listing to reflect that it's a 2022 model. Thanks!*
Explore Freedom and Versatility with this Ultralight Adventure Overland/Utility Trailer!
This AS-1 LIMITED was an AS-1 Limited Demo unit, purchased new by me in late 2022.
This A-Frame pop-up trailer has 9+ feet of headroom, with two queen bunks when in Camp Mode. The queen beds are completely modular for hauling mountain bikes, motorcycles, and quads. Perfect for a basecamp with the space and refuge you need.
This unit also comes standard with passenger and driver side kitchen/accessory boxes.
GVWR: 3,500 lbs.
Dry Weight: 2,800 lbs.
Gear Capacity: 1,000 lbs.
Towing height: 7'8" (Equipped with 33" BFGoodrich KO2's)
Length: 14'5" (without tongue) 17'6" (with tongue at towing length)
Width: 8' (Equipped with driver and passenger kitchen box)
Ultra-lightweight, insulated, four-season and modular. Built for off-road. Aircraft-grade aluminum construction means lifetime durability and no wood to rot or mold. This trailer can adapt to your needs, whether you want to sleep six people or haul motorcycles and mountain bikes. It is designed and manufactured by ANTISHANTY right in Logan UT, USA. Built by a team of outdoor enthusiasts with different passions of mountain biking, skiing, snowmobiling, dirt biking, hiking, hunting, and fishing. This trailer is your perfect companion for all seasons and off-road adventures.
Features that set it apart:
Available for inspection in Charlotte NC. DM me for more details and a ton more pictures if you're interested!
Asking $65,000 or best reasonable offer.
Antishanty Website: https://antishanty.com/products/as-1?variant=47385142952224
Walk-thru Video of this model:
GVWR: 3,500 lbs.
- Hard-Sided Insulated Cabin w/ 9-Foot Pop-Up A-Frame
- Fiberglass Reinforced Composite Floor
- Insulated Aluminum Composite Walls & Roof Panel
- Laser-Cut, Formed Aluminum Exo/Endoskeleton Frame
- 6 Arctic Tern Double Pane Insulated Windows
- Integrated Privacy Shades
- Integrated Window Bug Screens
- Triangle Roof Screen Kit
- Side Door Screen
- Rear Door Screen
- Tri-Panel Queen-Sized Bed/Picnic Table
- Second Tri-Panel Queen-Sized Bed/Picnic Table
- Modular Rails at 3 Heights for Varied Bed/Table/Bench Setups
- Indoor and Outdoor Aluminum Counters
- Keyless Entry Locking Doors with Deadbolts
- Lockable Front Gear Room for Wet/Dirty Storage or Easy Access
- Wallas® Diesel Cooktop and Heater
- A/C unit
- Deluxe on Demand Hot Water System with sink and shower
- 4 Expion 360® 100 Ah Lithium Iron Phosphate Battery
- REDARC Manager30 and RedVision system.
- 300 W solar panel, roof-mounted.
- 100 W Portable Solar Panel
- Dometic Fridge/Freezer
- USB and 12V charging ports
- 2,000 W Inverter
- 120V outlets
- Battery Shut-Off Switch
- LED Interior/Exterior Lighting Package
- Solar-Ready Port
- Shore-Ready Port
- Fire Extinguisher
- Electric Brake Package
- Two 23ZERO Peregrine 180 Awnings
- 33” BFGoodrich KO2 Tires
- Matching Spare Tire and Side-Mount Tire Rack
- Timbren Axle-less off-road suspension system
- Cooking and accessory shelf
- Coat Rack/Gear Bracket
- Entry Step
- Passenger-side Outdoor Kitchen/Accessory Box
- Dometic Fan-Tastic Vent (Roof Fan)
- Driver Outdoor Kitchen/Accessory Box
- Extreme Winter Triangle ThermoLiner Kit
