2022 Imperial Outdoors X-22 M+ 2nd price drop 58k (SOLD)
PhatPanda
500 dollars worth of Laveo dry flush cartridges included (24). Extra 2 gallon rotopax, 600 dollar Furrion wireless backup camera and screen, LevelMate Pro leveler for your phone via Bluetooth.
Stay warm this winter!
Venture to the ends of the world with the best mobile off-road habitat. From the tropics to the arctic travel in full comfort year-round. Spacious and comfortable, this is a true four season camper with the water tank all plumbing enclosed and heated. One of the best insulated trailers on the market with 3” thick walls and a 6.5 inch thick roof with dual pane acrylic eurovision windows with bug and black out screens. Fear no terrain with a fully boxed cabin and hydraulic suspension that raises 8 inches and lowers for easy towing with a 360 degree fully articulated lock n' roll hitch. Use the on-board air compressor to air up your tow vehicle and trailer’s 33” aggressive mud terrain tires.
Stay off-grid longer with no black tank, this model has the Laveo dry flush toilet sealing waste in mylar bags with no odor and a spacious dry bath with sink and on demand hot water from a 30 gallon fresh water tank. Store everything with ease using the incredible amount of interior cabinet space and multiple exterior storage areas including a huge passthrough under the bed.
The 2000 watt charger/inverter powers multiple 120 AC outlets all over the inside and outside of the trailer. The Dometic 13.5k AC with soft start will run for many hours off of the large 800 ah lithium battery bank. A huge 10 cu ft fridge and freezer keeps your food fresh allowing you to cook everything you would at home with the expansive counter top, 3 burner stove and oven.
We have traveled approximately 10k-12k miles in this amazing trailer and performed an incredible amount of upgrades and maintenance.
Here’s a list of the improvements and replacements done before, during and after our travels,
-3/2022 Propane upgrade
Replaced the two 20lb tanks with two 30 lb tanks
-7/2022 - Solar upgrades
Supplement the 2x190 watt Go Power flexible solar panels with 2x100 watt hard glass Renogy panels and 2x160 watt flexible Renogy panels. You could easily add more glass panels to the rack if you don’t need the cargo space. Upgraded the 30amp Go Power MPPT controller with a Renogy 50amp MPPT controller with Bluetooth capability. Auxiliary lead for an additional portable panel.
-7/2022 – Lithium upgrade
Replaced the 2x250 ah Go Power Lithium batteries with 2x400 ah reBel smart lithium Batteries which can be monitored by a Bluetooth app.
-72022 – Bathroom shower improvement
The hard glass sliding door makes the bathroom much smaller, and very common modification is to remove the heavy sliding door and install a curved shower rod and curtain
-8/2022 – Furion wireless backup camera installed
-10/2022 – Furion fridge fuse failed
Replaced and relocated to the front of the unit for easy access
-11/2022 – Inverter replaced
The Go Power 2000 watt inverter was replaced under warranty
-9/2023 – Awning replaced
Full awning replaced due to damage
-9/2023 – Full brake and bearing replacement
All bearings and brakes are now brand new!
Why spend 125k on a new Imperial Outdoors when you can get this amazing trailer for half the cost with all the issues worked out. We have saved you the hassle of working out the bugs with this trailer that’s been tested and is ready to go! This is an extremely comfortable trailer for a couple with pets or a small family. We are selling to downsize to a smaller trailer and smaller tow vehicle and are located in Santa Fe, NM. We will consider hauling the trailer part way depending on the distance and interest.
More photos to come soon.
Other quick facts:
-5200 lbs dry
-23 ft long
-RV Queen east west bed
-convertible dinette/bed
-Forced air heat
-Maxxair fan
-does not have the roof top tent
58k OBO
PhatPanda
Also has an additional 2 gallon Rotopax with lock. More pictures attached.
Psyph
