2022 Kimbo Camper for Sale $32,000
andrewbporter
Kimbo Camper #195 Details
Picked up at the factory in Bellingham, Washington May 2022
The Kimbo is currently located for pick-up in Sedro-Woolley, Washington, 98284
Here is the company web site: https://www.kimboliving.com/ There you can download the Kimbo brochure, see the specs sizes weight, etc and the current prices.
My Kimbo Build is #195, it included these options:
Kimbo 6 Standard features:
• Aluminum, riveted, sealed, frameless shell with brush finish
• R5 foam insulation with brushed fabric interior
• Teak entryway / mudroom with gear closet
• 3 – double pane Insulated windows with screens and black out shades
• 3 speed reversible roof vent fan with skylight
• 12v sealed battery with 110v outlets and USB ports
• High efficiency, dimmable LED lighting
• Loft bed area with full size mattress
• 2 cushioned areas for social seating
• Fire extinguisher
• Solar outdoor perimeter lights
• Exterior propane bay
• External 120v power connection
• High strength tie-down brackets
• Side mounted, removable jack lifts
• Weight approx. 900-1,200 pounds
These are the extra options included in this Kimbo 6 build:
Kitchen / Sink Module For use in food prep, hand washing, & as a bathroom sink: stainless steel marine sink mounted in birch plywood counter with hand pump faucet and 2.5 gallon under counter multi-use water tank for refilling hot or cold water.
Refrigerator Module For use in keeping food cool with minimum energy consumption: 12v/110v refrigerator 1.3 cubic ft. with LED lighting, exterior water-resistant removable louver panel with bug screen, weather intrusion channel, surrounding wood interior shroud and partial kitchen top.
Wooden Storage Unit and Table For use as your clothes closet with shelves that won’t fall out when you are driving: main clothing storage of interlocking birch plywood, mounted to center wall, dining / desk surface.
Solar Power System 200 Watt Solar For use in maintaining your battery energy for indefinite time away from an electrical plug in: roof-mounted waterproof 100 watt solar panel with mounted electric run, electrical connectors to battery transition, sealed exterior to interior transition.
Propane Fireplace and Chimney For use during the winter as a constant off-grid heat source: exterior vented propane fireplace with dry air, weatherproof roof chimney, 12v interior air circulation fan, 12v wiring run, and custom roof transition. Propane alarm.
Propane Tank 30 lbs, Cubby Door For use as a mid-to long-term off-grid solution to living while traveling untethered: high capacity 30 pound propane tank filled and fitted for year-round use, polyester tank retainment strap, insulated propane storage bay with water drain holes. Includes door and lockable latch to keep your gear out of sight and protected.
Rainbows over Kimbo.jpgIn addition to these options above the Kimbo I am selling comes with:
  • 1 Burner Butane/propane stove
  • Cushions, Pillows, sheets
  • Power drill for lifting/lowering
  • Dehumidifier
  • Tool kit
  • Power cable
  • Toilet
  • ¾ thick matt to put under the Kimbo (Fits Toyota Tacoma, w 6ft bed)
CharlieGreenT
